Looking at them in the shop the narrow wide tooth profile is very different to the normal ones.I think you will be happy with a 42, just as long as the chain stays on...
Just trying to cheer you up as you are bored and depressed
Next job but I will have to file it smooth first. Its a right mess!
Far beyond a sanding block. If I rub my finger across it will draw blood but I have a multitool with a little grinding wheel which should work. I have removed the front mech but need a few miles in before I pull the cable out.sanding block would be a better idea b4 braking out the big guns
You could also drop in a woolftooth roadlink into the back derrauiler and put on a 42t rear cassette and never worry about hills ever again.........Giant Road e+1, 1x11 conversion Report.
100 miles done with a good sprinkling of hills so a good test.
At or just above the cutoff I am happy in 7th and a downslope or tailwind that takes me up into the 20's is no problem and not once have I missed the 50T ring and higher gears, in fact I have only been in 11th a couple of times to see how it runs, and it runs fine. I took one link out of the chain to be sure it wasn't too slack, and once the motor shuts up the chain is whisper quiet and gear changes from 11 all the way up to 32 are slicker than ever with no missed changes, rubbing noises or chain chattering at either end, and of course no double shifting or chain suck which could be cos its all new, but I tend to think its the change to a narrow wide tooth profile that's making the difference.
I haven't been up any massive hills cos I use the e-MTB for those rides, but those I have climbed haven't presented any problems, and its great to not have to think about changing to the small ring before I lose too much momentum, so anyone with the Giant that fancies this I can fully recommend it.
Cost wise.. £115 But would have cost more to replace the arguably worn originals anyway..
Hope 42T N/W Ring and short bolts ..£50
Sram 11-32 Cassette and Chain........£65
Someone remarked that I may wear out the small cogs early, but it appears that you can buy them individually..
This is the first bike job that has gone completely according to plan so I am a happy old bstd.
Absolutely no need. I can climb any hill on my normal routes without needing either the lowest gear or full power, and bear in mind that adding a wide range cassette also creates big jumps in the ratios..You could also drop in a woolftooth roadlink into the back derrauiler and put on a 42t rear cassette and never worry about hills ever again.........
They aren't that big tho......I use a 38 upront and 10/42 rear on the ebike,I'm a big chap at 18st+ and being able to use those bigger gears means I use less battery in the big steep stuffAbsolutely no need. I can climb any hill on my normal routes without needing either the lowest gear or full power, and bear in mind that adding a wide range cassette also creates big jumps in the ratios..
Yes its horses for courses..They aren't that big tho......I use a 38 upront and 10/42 rear on the ebike,I'm a big chap at 18st+ and being able to use those bigger gears means I use less battery in the big steep stuff
I'm also looking at your quote, that you haven't done any massive hills and if you do, you will use the emtb..........with the larger cassette, you won't have to use the other bike for longer, steeper stuff as you quote
I have a custom titanium road bike running 1x11 sram etap hydraulic disc - 42 front, 10/42 rearYes its horses for courses..
I am surrounded by steep hills and like to ride over the moors (On roads) but the drop bar road bike with no suspension and narrow hard tyres doesn't really suit so I ride it more on the main roads, but will still climb 1500ft or more. For the up the hills and narrow pot holed roads I use the emtb as it's more suited to 20%+ gradients.. and then theres the down hills.. scary on a road bike!
What bike do you have?
Just realised that Strava actually shows the gradients, one of which is 17.5% which I climbed with ease in the middle power settings and I dont go up anything steeper than that on this bike. Another thing about this bike is that it gives buckets of torque at a relatively low cadence, unlike the Bosch which needs to be spun up a bit to get the power.They aren't that big tho......I use a 38 upront and 10/42 rear on the ebike,I'm a big chap at 18st+ and being able to use those bigger gears means I use less battery in the big steep stuff
