The new best headlight
  • Start date
6,733
yes but will try take it out that case and use a mount with a rubber clasp.
IR772
931
1,044
Leominster
Are you keeping the Dragon Mouth metal work as that seems an integral part to the light working to its best.
6,733
not to sure till i get it and have a look at it but think its more for a heat sink than anything else.?
it also has no on off but has 3 modes you just have to turn it on and of tho to change them.
or bust out the mode chip so its full on.
cant be worse than my other light i just bought a fkn match could beat that lol
IR772
931
1,044
Leominster
No don't be hard on the light, it was great until it started glowing inside and the board went on fire.
Remove all the heat sink as you go so fast the light will be super cooled from the passing air over it.
It is not going to get that hot and work off batteries, for very long anyway.
6,733
the 2nd light was the new one :rolleyes: worse than useless and was 28000lm
Gubbins
As the speed of light is generally not approached on most ebike journeys I think Phill requires the pool of light cast by the lamp to be a wide as possible for his eyes to scan, perceive and then take evasive action.
It's not the torch it's you.
Keep the two lights, the single LED (best in the world) for general use and traffic, and the very powerful car hater for when you wish to put yourself in harms way.
If I shine the light more horizontally to iluminate further away most of it goes up in the air. It lights trees up quite well.
Sent from my SM-G920F using Tapatalk
IR772
931
1,044
Leominster
I wanted photographs of Yorkshire tree boulevards lit up by your torch to look this fabulous, Blackpool do it so why not you?
6,733
i should get a refund for that light tonight as ill just leave even worse follow up feed back buy another 2 1 pound items and leave even more for selling cheap fake shite.
and just one this so i can test the discharge rate of the cells make my own packs and ballance charge them;)
awol
1,216
374
As the title says, this is the new best headlight.
Very impressed.
Given it's size I was expecting a dot on the ground with a large dim halo around it but in reality it throws the beam all round where needed and it even compares to my large 4-led light too which I didn't expect.
I can't see why anyone would need anymore than this for general cycling.
I also like the light around the edge which could be used around town to be seen but not dazzle oncoming cars.
On it's own this could replace both my lights I normally use for around town and dark unlit lanes.
Will be ordering a second as a spare at the price.
A great find d8veh.
6,733
Reactions: LeighPing
6,733
so if this cell is rated at 1600ma 580 of them are missing bit better than i thought tho but not buy much.
6,733
5,786
Your iMax is calibrated? My iCharger clones are off by 0.02 V but there is a calibration option to fix that.
4.17 V is quite good, my Samsungs after 18 months are at about 4.14 or 4.15 V balanced.
Reactions: soundwave
6,733
charger crashed but got 3102mha over 183mins @1amp from the panasonic cell.
6,733
its a real sky rc one but when i hold dec and enter when powerd on just says system update please wait so not like the copy's that go to a cal screen?
i think i need a new multi meter as that was like 10 quid in a kit 15 years ago and prob out more than the charger.
