The new best headlight
  • Start date
IR772
931
1,044
Leominster
That will be a very bright light.
I have a hand lantern with just 1 of these T6 in and it is like a white laser beam.
I just wish that they would stop adding the flash mode to all Chinese torches.
High and low or even a medium as well but NO FLASH.
chris_n
792
468
63
Niedeau, Austria
Just had a quick look on candlepower forum, they reckon less than an hour for a single T6 on an 18650. This light has 9 or 11 10w Leds.
Time to do some sums.18650 high power let's say 3000mAh these Leds pull 3A each, that is one flat (actually dead) battery per hour per Led!
Reactions: IR772
6,691
i have 4 grade a Panasonic 3400ma cells in my pack not the fake ones from china ;) the fan was 5V 2000ma.
chris_n
792
468
63
Niedeau, Austria
Maybe you don't understand the units 3400mAh = 3.4Ah = 3.4 amps for 1 hour = 1 dead never to be revived battery. A T6 led can draw 3 amps.
6,691
chris_n
792
468
63
Niedeau, Austria
Phil doesn't have 11 3A lamps on his though! It makes no difference where the cells come from of they are 3400mAh they can not give more than 3.4 amps for one hour.
Reactions: EddiePJ
6,691
my original pack i had with my light wont even last a hr on full beam the Panasonic ones out perform them and last hrs longer.
if you think it dont matter where the cells come from you are wrong the 18650 cells from china are fake thus why they dont last very long.
chris_n
792
468
63
Niedeau, Austria
You really don't have a clue what you are talking about. Look at the specs of the light 9 or 11 3 amp Leds your battery will only run 3.4 amps for one hour that is what 3400mAh means.
Or maybe you have invented free Energy!
6,691
the pack run a cree x3 led on max for 5hrs with a 5v 2000ma fan cooling it down as well and the cells were at 3.46v.
6,691
give it a week and ill test it and post the result i still have the old cells but if you think they will only last an hr then these things will last about 10mins ;)
chris_n
792
468
63
Niedeau, Austria
Finally something we can agree on! Won't be as bad if you keep it off full power though.
Maybe you would be better running the light off your bike battery, might shorten the range a little though.
6,691
bosch batt so got no chance doing that :(
Gubbins
