January 12, 20242 yr Hi everyone, I have a Swytch Max kit and wanted to upgrade the display, I purchased an SW102 display thinking the connectors would be the same but alas now both ends are female and a slightly different size. Anyone know if there is an adaptor cable available or would I need to try and make one. I believe they are Julet connectors? If anyone has been in this situation some advice would be great Thanks in advance Joe
January 12, 20242 yr Hi everyone, I have a Swytch Max kit and wanted to upgrade the display, I purchased an SW102 display thinking the connectors would be the same but alas now both ends are female and a slightly different size. Anyone know if there is an adaptor cable available or would I need to try and make one. I believe they are Julet connectors? If anyone has been in this situation some advice would be great Thanks in advance Joe Different LCDs have different software, different features and different comms. You can't just swap them around willy nilly. They need to be matched to the controller.
January 12, 20242 yr +1 as said , it is a waste of money to willy nilly just buy stuff withut knowing the ins & outs. Should have asked first. Some vendors of kits like to mess with connectors and put on the reverse of what is often available from a third party , that said if one hunts around an opposite M or F connector can be found . If the swytch is a KT controller then one can use any lcd from the KT range , KT LCD4 is similar in footprint to SW102.
January 12, 20242 yr Author Thanks - I should have checked more throughly but the SW102 looked identical to the one Swytch sell but you cant order from their website very easily.
January 12, 20242 yr Thanks - I should have checked more throughly but the SW102 looked identical to the one Swytch sell but you cant order from their website very easily. If you're replacing like for like, there's a good chance it might work. Cut off both connectors and join the wires colour to colour. Make sure that the battery is disconnected before you start, then short the unconnected red and black wires on the controller side to discharge the controller's capacitor/s.
January 13, 20242 yr M6 Julet 5-pin connectors are available on eBay. Search for M6 2/3/4/5/6Pin Cable Display Pin Base Connector Waterproof Connector. Link as follows:- https://www.ebay.co.uk/itm/354986608567?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=MpxFX55VRpq&sssrc=4429486&ssuid=IB4nVD07Rea&var=624267204160&widget_ver=artemis&media=EMAIL
January 13, 20242 yr Thanks - I should have checked more throughly but the SW102 looked identical to the one Swytch sell but you cant order from their website very easily. I’m kind of in the same situation. The Swytch Max uses a Lishui controller (as do their other kits). I bought a C500 display off of ebay for £20 that has a Lishui-compatable version. like you, I fell foul of it having the wrong plug. I will change the connector but I want to do some tests first. Two of the five wires (probably red and black) are the display power. Another wire is taken high when you press the display power-on button. These three wires should be easy to identify. The remaining two are UART in and UART out, so probably not going to be damaged if you initially get them the wrong way round. Either way, I’m not sure yet whether the display unit holds some of the settings for the bike that an alien display might mess up. I would imagine that all settings are held in the controller, but not sure yet. I started this knowing that there was a very high chance that I wasted my money, but I love a technical challenge (retired systems engineer). Chances of not screwing something up = 50%. Chances of a working successful new display = 20%! Advice to everyone - don’t try using a display not intended for your setup, it ain’t worth the risk!
January 14, 20242 yr I’m kind of in the same situation. The Swytch Max uses a Lishui controller (as do their other kits). I bought a C500 display off of ebay for £20 that has a Lishui-compatable version. like you, I fell foul of it having the wrong plug. I will change the connector but I want to do some tests first. Two of the five wires (probably red and black) are the display power. Another wire is taken high when you press the display power-on button. These three wires should be easy to identify. The remaining two are UART in and UART out, so probably not going to be damaged if you initially get them the wrong way round. Either way, I’m not sure yet whether the display unit holds some of the settings for the bike that an alien display might mess up. I would imagine that all settings are held in the controller, but not sure yet. I started this knowing that there was a very high chance that I wasted my money, but I love a technical challenge (retired systems engineer). Chances of not screwing something up = 50%. Chances of a working successful new display = 20%! Advice to everyone - don’t try using a display not intended for your setup, it ain’t worth the risk! Do let us know if you succeed we are all waiting with abated breath.
March 6, 20242 yr Hello, I have a 2017 model Analog motion AMX Step classic (original) and need to replace the display. Given the company has ceased trading, I have researched the sisplay is SW102/2 with a 2 pin plug. Does anyone know where I can find a replacement with a 2 pin, not 5? All insights very welcome!
March 6, 20242 yr First step would be to identify the make of the controller. The controller and display are matched - the vendors use different communication protocols.
March 6, 20242 yr Hello, I have a 2017 model Analog motion AMX Step classic (original) and need to replace the display. Given the company has ceased trading, I have researched the sisplay is SW102/2 with a 2 pin plug. Does anyone know where I can find a replacement with a 2 pin, not 5? All insights very welcome! How have you determined that it's a SW102/2? Are you sure it only has two pins in the connector?
March 7, 20242 yr Hello, its a Star Union Wuxing display. Upon closer inspection, the cable from the display is a 5 pin male connector, not a 2 pin. The cable from the battery is a 5 pin female.. Pic attached.
March 7, 20242 yr Hello, its a Star Union Wuxing display. Upon closer inspection, the cable from the display is a 5 pin male connector, not a 2 pin. The cable from the battery is a 5 pin female.. Pic attached. You can buy them from Aliexpress, Ebay or online Chinese resellers. Do a Google search.
March 13, 20242 yr Hello, me again. It's proving difficult to find a SW102 display with male pin for sale. Does anyone know if this would work? https://www.amazon.co.uk/Giilayky-Ebike-Display-Waterproof-Controller/dp/B0C84QNRQB/ref=pd_ci_mcx_di_int_sccai_cn_d_sccl_2_2/261-3444166-7890218?pd_rd_w=DI6dx&content-id=amzn1.sym.6448d24d-f04d-4e11-90e5-10165d266aa2&pf_rd_p=6448d24d-f04d-4e11-90e5-10165d266aa2&pf_rd_r=SSG11HQGDBKFFDT5F92K&pd_rd_wg=pyoQh&pd_rd_r=5631b6a5-1bf7-44f7-88b2-b19f1ce00246&pd_rd_i=B0C84QNRQB&psc=1
March 13, 20242 yr Hello, me again. It's proving difficult to find a SW102 display with male pin for sale. Does anyone know if this would work? https://www.amazon.co.uk/Giilayky-Ebike-Display-Waterproof-Controller/dp/B0C84QNRQB/ref=pd_ci_mcx_di_int_sccai_cn_d_sccl_2_2/261-3444166-7890218?pd_rd_w=DI6dx&content-id=amzn1.sym.6448d24d-f04d-4e11-90e5-10165d266aa2&pf_rd_p=6448d24d-f04d-4e11-90e5-10165d266aa2&pf_rd_r=SSG11HQGDBKFFDT5F92K&pd_rd_wg=pyoQh&pd_rd_r=5631b6a5-1bf7-44f7-88b2-b19f1ce00246&pd_rd_i=B0C84QNRQB&psc=1 No it won't work.
March 13, 20242 yr Okay, would this work? https://www.cycmotor.com/product-page/sw102-display Alternatively, if you can find me one easily, Ill buy you a beer!
March 13, 20242 yr Okay, would this work? https://www.cycmotor.com/product-page/sw102-display Alternatively, if you can find me one easily, Ill buy you a beer! That one will definitely not work. It has cyc specific firmware.
March 14, 20242 yr Okay, would this work? https://www.cycmotor.com/product-page/sw102-display Alternatively, if you can find me one easily, Ill buy you a beer! For that price, you can buy a KT controller and LCD4 or any other one of their LCDs, which is much better than the crappy controller you have. You might have to do a bit of wiring for the connectors. You can get a throttle too.
July 19, 20241 yr Hi, my Analog Motion AMX has a broken pedal assist sensor, couldn't find any replacement part so I'm selling my AMX electrical parts and will keep the bike as a normal bike. You can find my parts on ebay "verkoper_w", just FYI. Unless someone can give golden advice for the right pedal assist rotation sensor? Then I can keep my AMX electric... Edited July 19, 20241 yr by TimeFlies
July 19, 20241 yr Hi, my Analog Motion AMX has a broken pedal assist sensor, couldn't find any replacement part so I'm selling my AMX electrical parts and will keep the bike as a normal bike. You can find my parts on ebay "verkoper_w", just FYI. Unless someone can give golden advice for the right pedal assist rotation sensor? Then I can keep my AMX electric... It's a bit weird that the only part that you need help on is not shown in the photos. How can we help if we don't know what it is? The LCD will only work with your controller or one from the same kit, so you really need to sell the two as a pair with the cables. There are about 6 common versions of that LCD that all look the same, so somebody that doesn't know could buy it for their bike, but it won't work.
July 19, 20241 yr It's a bit weird that the only part that you need help on is not shown in the photos. How can we help if we don't know what it is? The LCD will only work with your controller or one from the same kit, so you really need to sell the two as a pair with the cables. There are about 6 common versions of that LCD that all look the same, so somebody that doesn't know could buy it for their bike, but it won't work. Hi, thanks for your swift answer, I don't have a photo of the broken rotation sensor, it's the bike repair guy who explained me that he tried several sensors and none of them worked for this bike. The only info I have is the type of e-bike: Analog Motion AMX Classic Thanks a lot for the info about the display, I'll modify to a combined ad. Kind regards
July 19, 20241 yr You need to get the broken part from the repair guy and /or take a pic , it is the only way we cen see waht you have. Typically PAS only has three wires so any PAS should work , but we need more help from you if you want our help with suggestions.
July 19, 20241 yr It's a bit weird that the only part that you need help on is not shown in the photos. How can we help if we don't know what it is? Exactly D8veh. !!!!!!!
July 19, 20241 yr You need to get the broken part from the repair guy and /or take a pic , it is the only way we cen see waht you have. Typically PAS only has three wires so any PAS should work , but we need more help from you if you want our help with suggestions. Thanks, I got these pictures from the bike repair shop, it's not exactly this rotation sensor but a look alike that he tried, the yellow connector is from my bike.
