The picture is of what I believe a Gen 2 controller looks like, but I’ve not had my hands on one personally!
\the accelerator is just a thumb throttle device.The battery pack will be self-contained with charger and bms integral to the pack. You only need to take the two wire output and join them to the controller (red and black). The battery pack’s only function is to provide your power. The pedal assist sensor is a three pin plug into the controller, which is 0v and 5v from the controller to the pas, and a signal wire back from the pas into the controller. The pas is just a hall-effect device giving an alternating signal as the magnets pass the sensor. Not sure what you mean by “accelerator handlebar switch”. Do you mean the display, or do you have a throttle of some sort? Either way, they would connect to the controller. I think the controller will have mainly the right connectors, but photograph the connectors when you remove the controller and we should be able to advise more then.
I am willing to be the guinea pig for this project, if you could recommend the battery, controller, and other bits I need, I am willing to have a go at completing the job. I want to get a 10 amp Hr battery or better, so the ball is in your court so to speak.I’ve been pondering this for a while as by brother has a gen 2 Swytch setup and both his battery packs are slowly failing.
There’s major sense ditching the gen 2 battery for a more generic one, but it potentially leaves you with an almost empty bag hanging on the handlebars that still houses the controller and display. A lot of battery panniers appear to have a controller box, so the controller could be reused, but you still would need a new display for your handlebars. It would be a nice thing to have a migration path for Swytch gen 2 owners to follow.
The first step is to take the battery and controller out of the bag, put it on the table, measure them and photograph them. If they're in a plastic box, remove the screws and photograph what's inside.I am willing to be the guinea pig for this project, if you could recommend the battery, controller, and other bits I need, I am willing to have a go at completing the job. I want to get a 10 amp Hr battery or better, so the ball is in your court so to speak.
The post I think you refer to is the one I did for the Gen 3 Swytch kit, where the battery clips off and the controller stays on the bike. This thread is for the Gen 2, where the controller, display, and battery are all in a bag that hangs on the handlebars.Search 'swytch connector' on this forum and scroll down the results list to several recent threads that probably cover everything that is needed.
Great info - thanks.The controller in the Swytch pack uses YLS connectors for the display, PAS etc, these are smaller than the normal Julet type. Then a XT30 for the battery and 3 pin MR30 for the motor phases. These connectors then feed into the connector on the back of the pack.
The matching connector on the handlebars then converts these connections into the more normal Julet and motor connectors found on KT controllers etc. The exception is the brake sensors which are 4 pin blue Julet, KT setups tend to use 3 pin orange julet or two pin red Julet.
Getting Julet cables for extensions is easy enough, dont know where you get the YLS type.
But you still need to use the multiway connector block in the bag mated with the matching multiway handlebar connector to connect the stuff like the motor, PAS, brakes, throttle ...............He has the connectors needed already - as long as there is a few inches of cable attached to them!
Not fully convinced of that - although I’ve not got my hands on a gen 2 controller yet. My reasoning is that for each cable connection to the controller (PAS, display, and motor) there will surely be a mating connector that cables up to the big connector. By cutting as close to the big connector as possible there should be enough of a tail on the connector to make up an adapter cable. There aren’t many wires in each connection - PAS has 3, display has 5, motor has 9. There’s even youtube vids on how to extend the display cable - so that’s well understood. Not for the faint-hearted I accept, but if it’s approached carefully and as Saneagle says, documented properly, it won’t be a hard job. Maybe a new controller is a good way forward, but at the moment he has a fully working bike and just needs a new battery. A new controller leads you down other paths and compatabilites that I don’t think are necessary. Phew! A long post - sorry!But you still need to use the multiway connector block in the bag mated with the matching multiway handlebar connector to connect the stuff like the motor, PAS, brakes, throttle ...............
That's excellent, thanks.Battery pack is 190 WX125 H attached are photos of battery and cables. I have no problem converting the bike into a rear carrier type set up, and extending the cables to the handlebars if this is the easiest route to go.
If your uses a sinewave controller, it must be sensorless. The picture in post #33 seems to show a sensorless motor, but it's not difinitive.The Swytch motor wheel is currently running just fine on my other Brompton with a normal KT Sine Wave controller and LCD4 display.
The cable from the controller to the motor has nine pins so it must be sensorless.If your uses a sinewave controller, it must be sensorless. The picture in post #33 seems to show a sensorless motor, but it's not difinitive.
