Return to the bent!
I had to put the conversion of my Velotechnic street machine on hold for a while, but now I'm back.DSCF3342.thumb.JPG.fde0d8beb929f374ef524b14b34550c0.JPG
I bought the bike with an existing 48v Dillinger kit that has got to go. The motor does not like hills and the battery is getting hammered, it may be past it's best anyway.
I have two 36v batteries, from my hybrid, that are good and will be used for now.
Following on from previous exchanges (particularly with Saneagle), I'm going with an AKM-128H with a dual voltage controller.
Here's the thing, I can only find the 128h with either 201 or 328rpm. Going into a 26inch wheel the 328 will be too high and, I suspect, the 201 too low.
On Topbikekit, the cassette version comes in 260rpm (which is lower wattage), but I have freewheel and they only do that as 201rpm.
Anyone got another reliable source?
Second issue is the display. As you can see it's mounted at the front by the chain wheel. It's the only place you can see it easily. So what I need is a display with seperate up/down buttons so I can mount it on the handlebars, like this:
https://www.topbikekit.com/ktlcd10h-meter-display-with-sm-plug-for-ebike-p-842.html?zenid=6dh0c7vjirbj8pb0l0atcfvb67
Can the cable to the buttons be extended without affectin operation?
  • Replies 105
  • Views 19.4k
I had to put the conversion of my Velotechnic street machine on hold for a while, but now I'm back.[ATTACH type=full]53313[/ATTACH]
For a 26" wheel, you can use the 201 rpm 36v one at 48v to get 260 rpm, 260rpm 36v motor at 36v or 48v, the 328rpm 36v one at 36v or the 328 rpm one at 48v or 36v. Basically, the 260rpm 36v and 328 rpm 48v ones are the same motor, and likewise 36v 201 rpm and 48v 260 rpm.
260 rpm gives a maximum speed of 20 mph (constant 18 mph OTR), and with 328 rpm, you get a max of around 27 mph (constant 24mph OTR)
What road speed would 201rpm give in a 26" wheel? (I don't have the maths skills)
I'll use the 36v batteries 'till they're spent, then I may go to 48v.
start with the circumference of your tyre:
26"
35-559
1990 mm
40-559
2030 mm
47-559
2050 mm
50-559
2075 mm
54-559
2100 mm
57-559
2120 mm
60-559
2160 mm
37-590
2100 mm
Assume you have 50-559 tyres, circumference 2.075m,
speed: 201 RPM * 60 (minutes/hour) * 2.075 meter = 25,025meter/hour = 25kph
201 rpm with a 26" wheel is approx 15 mph, but that's not the full story. That's no-load speed. The power ramps down in the upper speed range, so it would give good power up to about 12 mph and maybe 13 mph on the flat. That's with the battery fully charged. When it's full, you'd get about 10% more, and 10% less when empty, so somewhere between 11 mph and 15 mph, depending on the state of the battery. At 48v, it will be 30% more, so something like 15 mph to 20 mph.
Topbike kit have all speeds. It doesn't matter if you have freewheel gears at the moment. All you need is a cassette with the same number of gears, or you can use the opportunity to upgrade your derailleur and shifter. You can buy used 9-speed ones very cheaply from Ebay because many people want to upgrade to 10, 11 and 12 spd.
The cassette motor is a bit wider than the freewheel one with 7spd, so you have to dish the wheel a bit, the same as 8spd freewheel. Also, the actual rotor inside the motor is a bit narrower for the cassette version, so it can't manage as much power as the freewheel one, but it's still pretty good.
https://www.topbikekit.com/akm128cst-48v500w-rear-driving-hub-motor-cassette-motor-for-ebike-p-723.html?zenid=97ns4dhpp5rnhbb69lbic18on0
Edited by saneagle
Thanks guys.
I live in hilly west wales. I'm new to recumbent riding and I'm currently finding the hills painful, yet to build the different muscle set in my 70 year old legs.
So, we'd previously landed on the 800w freewheel as being more able to take the grunt to get me up the hills.
The bike has a bar end shifter indexed to 8 but currently restricted to 7 with a long cage deraileur. All sort of goes with the territory.
The motor you've linked comes in a 260rpm version but only in 48v meaning it would be even slower whilst using my 36v batteries.
This one comes as 36 0r 48 but only in 201 or 328
https://www.topbikekit.com/akm128hcst-36v48v800w-rear-driving-hub-motor-cassette-motor-for-ebike-p-982.html?zenid=97ns4dhpp5rnhbb69lbic18on0
:mad:Arrrgh!
Thanks guys.
:mad:Arrrgh!
48v 328 rpm is ideal. It becomes 260 rpm at 36v, which is also good.
There are three versions of that motor. All of them are included in that listing. The normal way to specify the motor is by the Kv. The three versions have Kvs of 5.6, 7.2 and 9.1. To get the actual maximum speed, you multiply the Kv by the actual voltage.
The freewheel version would be better, but only the one with Kv 5.6 seems to be available. If you're happy with 15 mph, it should be fine, otherwise it'll suck.
OK, gotcha. But will it develop the torque for west Wales hills?
It gets me up and down Ironbridge gorge, and I only run with 14A.
Well then that's good enough for me and if I ever run it at 48v the speed limiter in the display had better work and I'll carry an anchor just in case.
So, just to be clear 'cos it's 10:15 and I'm on my second single malt, it's this
https://www.topbikekit.com/akm128cst-48v500w-rear-driving-hub-motor-cassette-motor-for-ebike-p-723.html?zenid=nct5v7ps839lo53ovls5qpml85
48v and 328 rpm to be run at 36v so achieving 260 rpm,
:):cool:
Now to hunt for an 8 speed cassette with a decent range.
My 201rpm BPM [mention=22943]36v[/mention] tops out at 19mph with a 20a controller.
That's running at 48v, right?
Works for me. You can just see the buttons alongside the display on the far side of the mounting bracket. I've ape arms but the buttons would probably fit on the stem too.
I had to put the conversion of my Velotechnic street machine on hold for a while, but now I'm back.[ATTACH=full]53313[/ATTACH]
I have a tandem bent, finally found a round tuit to get it sorted, it has an old crystalyte 400 series dd front hub, I've just fitted a new KT controller and display, the up, on/off, down switch wire had to be extended to fit on the handlebars. I soldered the wires with small heat shrink on each wire and then a larger heat shrink over the lot. Works fine. The same had to be done to tidy up other wires, mostly too long. Given the age of the original conversion I've legally got a throttle, useful for setting off.
PS... Whats the handlebar mirror? Could be useful, I find the helmet one a bit small. My handlebars are the other way round to yours but there will be a way.
I was just going to press the order button and found myself hesitating. Sorry to labour this but I want to be sure before spending my hard earned.
So, I'm going to order a 48v 328rpm motor and run it at 36v to get 250rpm.
I'm assuming that running at the lower voltage it will need more current to get max rpm, so will a 22A T09s be enough?
In a 26" wheel (with 35-559 tyres), this will give a no load max speed of 28kph, so good for legal limit.
Am I getting there?
Thanks Jim, good to know.
No was at 36v, It was a Woosh kit thye came via John at Cyclezee.
The RPM rating is confusing. There is no agreement between manufacturers for labelling. I much prefer Bafang winding code. We always make sure that the motors are at their best between 12mph and 15mph. That's because 12mph for climbing a moderate hill, 15mph for cruising. Maximum derestricted speed is 21mph for 26" wheels, 22mph for 700C. 48V motors have 30% more turns to yield the same sweet zone.
Am I getting there?
That's all correct.
It's not 201 rpm then! Somebody might have said it was, but clearly they were wrong.
Just putting the shopping basket together.
I need a display with seperate buttons, was looking at LCD3 - is this going to give me the best functionality bearing in mind I'm going to need to set cut off speed?
The shape of the LCD8s would suit the fitting location better (at greater cost) but not sure if it's trying to do too much.
Any thoughts?
Any thoughts?
LCD3 is good, so is LCD8. Avoid LCD1. LCD5 looks a bit crappy. LCD4 buttons are a bit too small. The rest are OK, I think.
Any thoughts?
The lcd3 I just fitted had a separate wired 3 button switch, it only has a short wire to fit on handlebars next to display, I had to extend it to fit between the display on the bent boom and the handlebars.
Thanks guys, think I'll go for the 3 as I've seen it mentioned a lot in posts so there'll be plenty of help with any programming issues.
Having spent a long time carefully formulating the order to contain exactly what I wanted, I somehow selected the wrong payment method. Topbikekit are now waiting for a payment from Wells Fargo which I can't make.
AAARRRRGH!:mad: Colour me stoopid.
I've sent customer support a message and await the reply.
I've had a mail back from topbikekit telling me that I can pay their paypal with a link:
topbikekit@outlook.com
But this is an e-mail address. Anyone know how the hell I use a credit or debit card to pay this? I don't have a paypal account.
