Resistors on voilamart front wheel hub
mikeconnect
344
9
Warrington , Cheshire
I repeat my question . The cables appear to go underneath the board so I assume the connectors are underneath the board . My question is how do I remove the board
mum not working it’s a pity I can’t text or something so I can keep It goingIf I have query
mikeconnect
344
9
There's no connector. It's soldered.
I appreciate your help really but Please clear message please you said this
Follow the cable out of the motor until you come to the end. That's here the connector/s is/are. Please answer my question
The wires out of the motor go underneath the board . So I repeat
1. Do I need to get underneath the board ?
2. how do I remove board to get underneath
3,994
I'm talking about the motor cable that comes out of the axle and heads off to the controller - the thick black wire with cables inside it. The wire that you had to unplug to remove the wheel from the bike.
mikeconnect
344
9
The cable doesn’t unplug At the wheel end This was a replacement for the original Giant wheel . Hence the previous owner fitted voilamart wheel but fitted but the cable Which is threaded through the axle and the wires are directly soldered to the board.. no wonder I can’t follow you . So what now ? Look at the photo again and say which colours need probing and Can I do it this way as the Cable wires are SolderEd directly in. From what you say I would have to disconnect the soldered wires and bridge them with the probe ???
UPDATE . The 5 wires while still soldered to PCB all beep . So is that a safe indicator ?
8,843
As the hub spun out of the drop outs have you tested the controller mosfets as a wire short may have blown one of them.
mikeconnect
344
9
Well I want to eliminate the wiring first because things have happened ref other things which I’ll explain later . Is the wiring ok ? Dies the beep test work this way if the wiring is directly soldered to the PCB and there’s not a plug connector ? Cos I’m not a regular with these circuit testers
