Guys, I finally received the exhaust clamp today.
I started a prototype on a cardboard:
- I've put the 2 exhaust clamp on the top of the frame because on the bottom it may slide with the weight and wouldn't clamp that well.
- I added 4 layer of small cardboard to prevent the steering tube to touch the battery box. I'm planning to replace them with wood as it's quite lightweight.
- The last and longer layer represent the battery box. I'm planning to directly fit a box of 8mm polycarbonate sheet on it.
A view of how the back side of the battery box would be clamped:
I'm still wondering if 8mm polycarbonate sheet bolted in 4 area would be strong enough to handle 20kg bag with vibration and jump...
I'm thinking about adding a steel plate on top of that... or maybe use a 3rd exhaust clamp to have 6 fixation point?
What's nice about that is that I won't need to be worried on my battery being stolen after that as it would be strongly clamped to the bike.
What do you think guys? 8 mm polycarbonate with 4 fixations point should be enough? All goods, can I go into production?
