Please don't use the glue... It will only make the situation worse (that's if it can get any worser)
Fairly sure Brompton specify 10kg for the front luggage block.I think 14kg exceeds the block carrying weight anyway which is why it might have failed.
Jerry
Yep I do thatToo late for the OP, but the moral is regularly check the block fixings for tightness.
I actually made a slot through the block center (drilled two holes then filed them out to a slot) which I feed the clip through as shown on the bike above. I am not sure if that will work with the Brompton as it will be dependent on the space on the frame to then put the jubilee clip round. I covered mine in wp tape. The slot in the block needs to be in front of the flat plate where the original screws sit.And can I use this type of clip?
ps: looking at it again, it seems very DIY. So you basically drilled a flat hole in order to put the jubilee clip?
It would probably make sense for me to drill 2 flat hole and put 2 additional clip.
Thanks Jerry
Jerry, in the photos I've just looks at it looks like there's plenty of room.Whilst they would be a good solution for many generic bikes there just would just not be sufficient clearance on the Brompton frame for those, I doubt the JC will even fit either.
Jerry
