Q128C seems very slow - normal or not?
17,290
Yup, another motor upside down. it won't last 5 minutes in the rain like that,
regarding the torque arms, just make sure that the nuts are nice and tight.
Reactions: Forge Custom
8,781
No matter how much silicone or grease or whatever you gob on to it, moisture will always find away and track down in to the motor. Eventually rust will seize it up or it will fail.
Benjahmin
2,718
1,791
71
West Wales
Speaking as an electrician, any cable entering a device from the top will allow water into the device. Doesn't matter what you do to it, water will get in. Turn the axle so the cable faces down and forms a drip loop, you'll save yourself a mountain of aggravation.
Forge Custom
88
58
Dorset
When you say upside down, is it just a case of undoing both axle nuts and spinning the whole assembly? Or is it more complicated?
Sorry for the technical stupidity. Why I had someone else do the mechanical bits. The sourcing and the riding are my area!
Cheers
Matt
Benjahmin
2,718
1,791
71
West Wales
Undo the nuts, take the axle out of the dropouts, rotate the axle by 180 degrees, put it back in. You may need to release some slack in the cable that goes to the motor, so have some cable ties handy to re fit it.
You want the cable to loop down, like this (I know this is a front hub, but the same applies):
p.s. Look at the chillies on the plant in the background, that was a good year for chillies:cool:
Forge Custom
88
58
Dorset
Top stuff - cheers for that. Nice chillies too!
You have to take the anti-rotation washers off the axle and rotate them 180deg before putting back on.
