Q128C seems very slow - normal or not?
There isn't a white speed restriction wire. Are you sure your mate knows what he's doing?
Forge Custom
88
57
Dorset
I hope so! Was just going by Nealh's advice earlier in this thread. Haven't seen it personally yet. What is Neal referring to then? Apparently he found a white wire and disconnected it.
8,593
Reactions: Forge Custom
Forge Custom
88
57
Dorset
OK - trumpet fanfare - just been to pick up the bike. Mysterious white wire found and disconnected and ..... she flies like a bird. Thanks Nealh.​
Only thing I've noticed is that the motor seems to cut out at what must be getting towards top speed. Soon comes back again. Is that because I've reached the top speed set on the LCD maybe?
If you get cutting out at a particular speed, the controller is limiting the speed. Without a speed limit, you can't feel any cut-outs. You just run out of power.
8,593
Depends what speed you cut out at now ?
You will have either reached the optimal top end speed for hubs rpm @ the supplied voltage or need to set the lcd speed setting a bit higher.
Pointless setting the speed on lcd to 70mph as you never peddle that fast for mine I just set it between 32 - 45km/h / 20 - 32 mph.
Forge Custom
88
57
Dorset
Looks like it's set to 72km/h.
5,786
You have a speed limit set somewhere. You just have to find it.
Try this: make a note of all the settings, then do a system reset back to defaults. See if that clears it.
Forge Custom
88
57
Dorset
Hi. Slight spanner in the proverbial works possibly. I've just found both torque arms I bought still in the box of bits! Hadn't noticed. It's a steel frame - is this likely to cause me any problems?
5,786
Depending on dropouts you don't usually need them on a steel frame. If the dropouts are very thin they might be a good idea.
