Problem with my Bafang HD
8,598
Pawls all vary in size.
Reactions: Hixyhicks
Hixyhicks
151
10
55
I have put a very short vid on youtube .I have put it all back together and its still playing up .
3,993
This looks like the version you have. he got the number of balls wrong - one too many in the inner race and one short in the outer:
Hixyhicks
151
10
55
My wheel is brand new.I swapped the wheel for another and the problem still persist ,im getting fed up with it now.I will look up checking the controller with a multimeter and see if its the controller .Maybe its the gear the clutch sits in though it looked ok to me .
3,993
I have removed the potting,can you tell me the best way to test this now please .
You didn't need to remove the potting. You test through the wires.
Measure the resistance between each phase wire and the battery positive, then repeat for the battery negative to get 6 measurements. each group of three should be the same as each other and in the range 7k to 24k or thereabouts.
The other thing you should test is the hall wire connector. it has white rubber stuff to hold it in, but sometimes they don't plug it in properly before they put the white stuff on.
Reactions: Fordulike
Hixyhicks
151
10
55
Thank you give me a clue how i do t his ?.The phase wires are the yellow,blue, and green is that correct? I have my meter what setting do i put it on ?
Hixyhicks
151
10
55
Thank you
Green positive 40k> minus 08.0
Blue positive 40 k> minus 07.8
Yellow positive 40k minus
I checked the main harnes connection and only got an output on 1 +3
42305
