4,800
1,258
How Invasive Plants Are Fueling California’s Wildfire Crisis
Non-native grasses and eucalyptus trees were brought to California centuries ago for agriculture and landscaping, but they’ve changed the state’s natural fire dynamics.
Reactions: POLLY
4,800
1,258
World’s only floating nuclear plant generates record 1 billion kWh power before refuel
The two reactors of the floating nuclear power plant underwent refueling after five years of operation
Reactions: POLLY
4,800
1,258
New water purification technology helps turn seawater into drinking water without tons of chemicals
"“Our device reduces the chemical and energy demands of seawater desalination, significantly enhancing environmental sustainability and cutting costs by up to 15 percent, or around 20 cents per cubic meter of treated water,” said Weiyi Pan, a postdoctoral researcher at Rice University and a study co-first author."
4,800
1,258
Why the next energy race is for underground hydrogen
Hydrogen can be used in chemicals and as a green fuel. Vast underground stores could help make it an economical option.
Reactions: POLLY
4,800
1,258
4,800
1,258
Reactions: POLLY
17,440
China claims major fusion advance and record after 17-minute Tokamak run
1,066 seconds of steady-state high-confinement plasma operation and all that
https://www.theregister.com/2025/01/22/china_tokamak_plasma_record_claim/
I spotted a small mistake in the article. It said 'Creating plasma and keeping it contained is hard. Tokamaks do it in a chamber, often doughnut-shaped, that contains gases that are heated to high temperatures and subjected to enormous pressure until they becomes a plasma'.
Inside the tokamak is near perfect vacuum. The pressure is very low, about 1/10,000,000 atm - the opposite of enormous.
Still, it's a record to keep the plasma going for that long. Usually, when fusion starts, the reaction generates so much heat that destroys the coherence of the beam pretty quickly. The trick is to constantly adjust the current in the magnets to keep the beam going.
Reactions: POLLY
G
Ghost1951
We already have a working fusion reactor. It has been working for nearly five billion years.
61874
Fully working. No need to mess with it. All we need do is to collect the trillions of kilowatts it pours down onto a variety of desert areas, store some of the heat in molten salt and run our steam generators 24/7. The Maghreb area of North Africa has access to this amazing reactor for twelve hours a day and it is fully usable 97% of the day time hours in a year.
61875
Part of the Noor solar thermal power plant in Morocco.
61876
Why make things so difficult trying to replicate the sun on earth. We are NOWHERE NEAR doing that and anyone who thinks we are needs his head examined.
We can do this NOW. The heat can be stored for nighttime use and that is what happens at these concentrated solar thermal plant.
The solar energy absorbed by a square meter of the Sahara in an hour is between two and three kilowatt hours of energy. FAR more than we get in our feeble solar systems on UK rooftops where the energy available is about 850 to 1000 watts per square meter.
The power is easily transmitted to far flung places on ultra high voltage DC lines which lose very much less power than AC systems - 3.5% for 1000km - much less than AC - especially under sea.
17,440
It's a question of space. We'll need fusion reactors to travel to the stars.
Reactions: POLLY
2,858
Widespread power outages in Northumberland and Durham. More or less most of the rural communities are off grid right now. No charging today then...
Not a day to use the A68.
charging : Yes you can. You've got to stay home, so you can charge off your exercise bike.
Reactions: Ghost1951
