Ok ill try and keep this short and to the point as I can.
Yose 350w rear hub kit. 1st things starting happening:
- speedo on the lcd and motor watts occasionally stayed at 0 whilst cycling everything else worked fine.
- all power would cut to the motor, lcd still on battery voltage fine. power on and off and all good for a mile more till that happened again.
- noticed the icon that appears on the lcd3 that indicating brake was being applied stop appearing even though brake cut off switch working and cutting motor as it should.
this carried on for a while then:
- power to motor seemed to be at max assist regardless of assist setting 1-5
- started having full power assist when lcd was set at 0
- eventually power became very low only noticeable up to 3-5mph.
- if i hold throttle open full the motor spins at 5mph ish and then slows a little more
things I've checked:
- check all connections
- check with a pin and a multimeter that the 4-1 cable has no breaks or shorts
- confirmed the same behaviour (low power) with just throttle connected or just pas sensor connected.
- had a look inside controller - can't see anything blown
- checked none of the three phase wires in controller are shorted to negative or positive cable
So decided it seems most likely the controller that has failed and its good excuse to upgrade to 48v battery and controller.
purchased new 48v battery and this controller .
I plugged in the controller and new battery to existing motor and kt-lcd3, controller came on and showed new 48v battery reading. great i though all should be good - tried the throttle ( bike in a stand ) wheel spun but still not full speed, tried via turning pedals - again not full speed, then tried the throttle again started to spin then shut off - lcd also went off like complete loss of power.
Since then with the new controller and battery attached i can turn the lcd on but can not get any power to the motor throttle or pedals! - has this new controller failed ?!
whilst It did work for a min on first connection i noticed the speedo was still reading 0 as was motor watts and the brake still didn't show the brake active icon on the lcd.
This led me to think perhaps the KT-LCD3 is faulty from rain water damage and is causing problems.
Purchased a new KT-LCD5. plugged this in with new controller and battery but still nothing - no power to the motor.
Decided to try original battery and controller again. Could now get same behaviour as before, motor only spinning slowly from throttle/pas, no speedo, no motor watts showing, no brake indicator. This is the case using with KT-LCD3 attached or new KT-LCD5 so I guess i've ruled out the lcd being the problem.
Took the wheel off tonight and opened up the motor - all looks clean, cables look ok don't really no what else to look for there. with a multimeter i have continuity on the end of the 9 pin cable between the three big phase pins. motor is stiffer to turn if i short these as i've read it should be if its working. Checked for continuity between middle negative pins and all other pins and there isn't which i think is correct.
Not sure what to try next - im hoping it is still the controller that's at fault but cant understand whats happened to the new controller to the point that now doesn't seem to work at all other than allow me to turn he system on.
any ideas or further troubleshooting ideas appreciated
