Great bike Tex. I'd imagine there's no feeling quite like cycling with 800W of additional power. Those forks are worth more than my entire bike! It just oozes quality.
i did not end up getting the external battery, as with 80K of range i've not yet had to call on the extra air.TEX
I got hold of a Optibike 600T and its like new and was never really used
and I was wondering if u had the external battery...
and can I use the internal battery charger on it?
I was also wondering if I could upgrade to the 850 motor in the future and
is it a simple task of motor swop or is there more to it?
That's probably an XLR connector Steve, not DIN, though if a fraction smaller than XLR an NTC microphoneI have found out I need another charger for the external battery and it must have a 3 pin din
connector. You can buy an XLR plug from Maplin and fit it to whatever charger you buy, but make sure the
connections are the right way round. Only the outer two are used on a Li-ion battery, pos and neg, the centre
one is left free.
Before soldering on the wires, make sure you've put the other XLR plug parts onto the lead as shown at the right,
first the rubber grommet (1) the right way round, then the body (2) as shown, last the clear insulating sleeve (3),
cone larger side towards the cable end. When soldered, slide the clear cone over the three solder connection
tags, then slide on the metal body and tighten it's screw firmly, finally twist in the grommet head and replace the
cable clamp and screws. The XLR one illustrated below has the third wire since it's for an NiMh battery:
I don't know what the capacity of that battery is Steve, but the eZee li-ion/li-poly charger for their 36 voltI was wodering do I need a special charger from Optibike for the batterry?
I would like one with a fan cooler
I have shown it above in the picture or can I buy a generic one and can I use one off BMS Battery site and what would u recommmend as its 36 volts
and the motor is 600 watt ok
14 Ah is fan cooled and comes with an XLR connector already on. However, you'd need to check the connections
were the right way round for your battery and if your connector is the smaller NTC one you'd still need to change
that, but it should be ok for you otherwise.
Being a charger from a bike supplier it is fairly expensive at £100, so it might be just as well to get the Optibike
one if that's not too much dearer.
I love riding it and I can live with the front mud guard and not going out in the rain its to wetIts a really interesting looking bike Steve, enjoy the heck out of it. The only thing I don't like is that front motor bike style mud guard. Its not really long enough you're going to get covered in muck real quick in bad weather!
Can I come and stay with you Tex and bring my bikeCan't say I miss the Nicosia here on Sydney. Too warm and sunny!
That's £99 at today. If you choose the normal USPS express (about 12 days) or standard postal service, rather than a courier like UPS, it shouldn't cost too much P & P. Although a bit dearer overall than the eZee one, it would be absolutely right with the correct connector.optibike charger is $160 plus postage what ever that will be
I have been quoted $245 delivered from Optibike so looks like best betThat's £99 at today. If you choose the normal USPS express (about 12 days) or standard postal service, rather than a courier like UPS, it shouldn't cost too much P & P. Although a bit dearer overall than the eZee one, it would be absolutely right with the correct connector.
