Nyon or Kiox retrofit?
6,592
dealers cant open the motors even to fix a 5 quid bearing and all must be sent back under warranty.
i swapped my motor over and only takes 20 mins to do the hole lot.
Vim Fuego
64
Interesting. It does look pretty straight forward but with my bike being just a week old I think I’ll let the professionals do that bit. :)
So I have send other videos, where the motor can be dropped out, without removing the pedals, I also have a regular crank on mine (gen 3 performance line), not the small cog on the one seen here.
The Silverfox
86
45
Cardiff, UK
My Nyon was delivered yesterday. Dropped it into the Bosch Service guy in the afternoon along with the bike and picked it up this afternoon. He said it took him about an hour to fit. All seems to be working as far as I can see. I’ve linked it to the eBike Connect app on my phone which took about 20 seconds and will be giving it a run to try the navigation, etc. in the next couple of days.
Reactions: Vim Fuego
The Silverfox
86
45
Cardiff, UK
I went out for a ride today to try out the New Nyon. It started off well but then I had issues.
When you press the on button it take about 15 seconds to start up to the main screen. I find the screen to be a bit sluggish. There isn’t an instant response when you tap a button or icon, there is a delay. When dragging left or right to go to other screens it is a lot less responsive than a phone. When you’re on the bike, though, you are more likely to be using the buttons on the controller to move around and select things which doesn’t make it so evident.
I set up a route with the eBike Connect portal as a round trip in my local area. I had some errands to run so set two waypoints for where I needed to go which gave me a route of 12 miles. It chose a different route than I would have. However, it did use more cycle paths than I would have because there were some I didn’t even know about so I was happy with that.
The display is good and the information clear. The colours certainly help with clarity. The maps are quite clear and you can move around on the map and zoom in and out. I did find on a couple of occasions there was a slight lag with the map showing me where I was on the route and consequently passed a couple of turnings so had to turn round. I guess as I get used to this it will become less of a problem. The audible beep when there is a turn coming up helps to get your attention if you aren’t looking at the screen. If you are on one of the other screens a notification showing the distance and an arrow for the direction appears overlaid shortly before the turn.
The function on the maps that overlays an area centred on your location to show you what range you can expect in whichever power mode you have selected is very clever and I can see me using that a lot. The only flaw I can think of is I typically do a round trip either from home or from a location I’ve driven to so I would really need to know the area I am able to ride taking into account the return to where I started. It may do that, I just haven’t found anything on there that suggests it can.
After the ride by the time I got inside the ride data had been uploaded to the eBike Connect app and web portal. This is when I started to get problems. I pressed and held the on/off button to turn it off and it wouldn’t. I tried a number of times and it just wouldn’t turn off. I took it back to the bike, thinking that perhaps I needed to turn it off while still in the cradle but, no, it still wouldn’t turn off. In the end I did a forced soft shutdown (hold both the on/off button and the light button down for 30 seconds until it shuts down).
I then restarted it to make sure it would turn off and on properly which it did but then I noticed that it wasn’t connecting to my phone via Bluetooth. I tried everything, restarting my phone, restarting the Nyon, but it just wouldn’t connect. I did a factory reset and that seemed to solve the problem. I connected the WiFi and Bluetooth again and it picked up all the information from my eBike Connect account.
I had bought the Lock function in the app and went to enable that but noticed it was missing, probably due to me having to factory reset it. I had to go into the Store section of the app and Restore the purchase to get it back. I must admit, though, I am a bit nervous of using the lock feature at the moment as I’m not sure if I’ll be locked out of the bike if it decides to play up again.
DiggyGun
134
57
England
I use the lock feature all the time and have never had an issue with it.
Reactions: The Silverfox
The Silverfox
86
45
Cardiff, UK
Vim Fuego
64
Turned up today. There was indeed £55 Brexit charges, and £12 customs charges. So about £320 on total.
Not fitted it yet, but charged it up, updated firmware and had a tinker. So far impressed. Very responsive and comprehensive.
The Silverfox
86
45
Cardiff, UK
Great news. When are you planning on installing it?
The Silverfox
86
45
Cardiff, UK
Weekend task. I need to find out the torque values for the motor mount
Vim Fuego
64
Interesting development, I took the plastic housing off to see what the job looks like, and to my untrained eye, I don't need to even touch the motor mounts, I can access the holes the wires come out of, in-situ, in my Haibike.
Anyone confirm?
The Silverfox
86
45
Cardiff, UK
Mines a Cube so not the same but by the pictures it looks like it could be quite an easy job. Probably get it done in 10 minutes ;)
Vim Fuego
64
Turns out the problem was not getting to the down tube, but getting the old lead out, I have left it in situ and ran the new one alongside. And round the motor, not under (there is plenty of room behind the plastic housing to go around rather than under, so go knows why haibike ran the cable there)
6,592
just take out 2 of the motor bolts and then swing the motor out the way and can then remove the old cable.
Vim Fuego
64
I did that in the end. I really wanted to avoid touching motor bolts, due to aligntment issues and torque settings. In the end, it's all assembled, I just need to tighten the Torx T30 screws when my amazon torque wrench arrives tomorrow (mine didn't go low enough), and buying a cycle torque wrench was only £24, still much cheaper than getting some trainee at my local Bosch centre, who didn't know anything about what the job entailed, or even if it's something they could do charging me £50 an hour, or part thereof. I now own a cycle level 5nm to 25nm torque wrench and also know the work has been done correctly :)
