I could see the Iris being aerodynamically highly efficient and effective in dealing with frontal resistance but cross winds could be a significant concern. I don't know the coefficient rating. It would be interesting to know.
The 750w would require registration, insurance and a licence. It may also require a helmet which would be very warm in an enclosed environment. The 750w would not qualify for cycleways and is a road vehicle. That said, it is the model which appeals to be because it has a mid motor on the cranks and is better balanced. The power to weight ratio looks good.
Rolling resistance should be low. Add a 750w and the right gearing and keeping up with traffic in a build up urban area would not be problematical.
The acrylic front may need to be coated so as to avoid fogging up unless the vehicle is very well ventilated. Remember internal moisture from exertion will add to the water vapour level as a result of sweating.
The steel chassis may obviate the need for suspension but at a cost of aerodynamic efficiency I would be tempted to use Schwalbe Big Ben or even Super Moto tyres.
Impact collision could be dangerous. This is not a strong monocoque construction. The only possibility would be that the Iris might be so light as to be pushed easily away and no significant inertia to prevent this. A 3 point harness might be sensible. How to retain this harness might be a challenge.
From some angles, visibility in darkness would be a problem. Adding retro reflectivity would help.
Torque level looks good.
Adding a second wheel at the back to make a quadricycle could have added to stability but would have compromised the body shape.
All in all, I'm open minded to this as a radical transport solution. Parking and storage may be a problem but floor space is not huge. I see huge eco advantages and the charcoal filters may be effective.
I'd guess that you would need to be reasonably agile to get in and out.
Interestingly, the Iris might actually be viable without a motor , entirely unassisted if the tear drop shape is aerodynamically efficient enough.
I'm going to pay a deposit although I will need to make sure that tax, registration and insurance are not disproportionate.
