New Bosch Coming!
tillson
5,252
3,197
Again. Should t we be more interested in an honest torque figure?
Torque alone is meaningless. With the correct gearing, I could make the motor which drives the second hand on my wrist watch produce more torque than a Bosch motor, or any Ebike motor for that matter. It would be more meaningful if the manufacturers quoted T Nm at W rpm for example. Then you would get an idea of how the motor will perform on the bike.
JohnCade
1,486
736
Bosch 500 Watts
Yamaha 580 Watts
Bosch performance 940 Watts
The maximum wattage is more relevant than a torque figure IMO, and I wanted to know what it was for different motors. What is it for the Impulse 11 I wonder. On those figures the Bosch performance is a lot more powerful than I thought it was.
Hold on. You didn't read what I wrote. Also, I guarantee that the Bosch doesn't make 75NM at 120 rpm. It might make 75NM and it might spin to 120 RPM, but not both at the same time.
According to Martin's website, the Bosch sprocket rotates 2.5 times the speed of the Yamaha for the same bike speed. If the Yamaha makes the same torque as the Bosch, it would produce 2.5 times the power, which clearly it doesn't. The above claims of torque are absolutely meaningless.
Reactions: soundwave
tillson
5,252
3,197
Forget about torque, power is the issue and power=force x speed.
which equals torque x motor shaft speed, so to torque is very relevant.
I'm just taking Martin's torque and motor speed figures at face value. I don't know whether they are correct.
They can't be correct because they have completely different sized motor sprockets.
To be meaningful, the torque would have to be quoted as something like 60NM back wheel torque in bottom gear with a 34T bottom gear sprocket. If there's options for the motor sprocket, that would have to be declared too.
JohnCade
1,486
736
So since as I always suspected these torque figures are essentially marketing terms and so meaningless. What is the relative power or wattage of the main CD motors? I assume wattage would be the best way to measure power output at these sorts of levels.
They won't want to say because of political implications. That's why they use torque.
ray74
118
16
So is the new Bosch cx motor more powerful than the Yamaha do you think? Just wondered as I'm not sure which one to go for. I have a haibike with the yamy motor at the moment but just wondered if I would notice any difference in the new Bosch?
Are you sure you're not getting carried away with hype? Does your Yamaha not provide enough torque? Don't forget that any extra power will have to come from the battery.
ray74
118
16
Yeah you're right. Thinking about it after I wrote that I thought there's no point changing to a Bosch if I'm so happy with the Yamaha. I am changing to a full sus but going to stick with the motor I know.
RobF
4,732
2,312
If you are changing to full sus anyway, it would be worth trying a Bosch.
They do ride slightly differently, the Bosch being a bit smoother and more refined.
The Yamaha motor is probably on a par with a Bosch, possibly the Performance version.
I've not tried a CX, but the Performance has noticeably more poke than the standard, so I expect the CX will be pokier again.
In other words, you can believe Bosch when they say the CX has more torque, even if the quoted figures are meaningless in use.
Another plus for a new Bosch is the option of a bigger 500wh battery.
On t'other hand, Yamaha bikes have a standard size front ring and can run two rings at the front.
Superior, in my view, to the tiny front ring on the Bosch bikes which I see as giving no advantage.
6,514
you can put 2 on the bosch 14t +16t ect tho will have to manually change them.
ray74
118
16
Yeah I tried both Bosch performance and Yamaha at sherwood pines late last year at a haibike test day. I preferred the Yamaha more that time because it felt more instant and pokier. One of the main reasons for looking at the 2016 Bosch was the 500Wh battery and the little extra torque but the xduro allmtn Rc costs £3800 and the Sduro Rx costs £3700 but gains better brakes, dropper seat post and the E.I suspension. ( bit of a no brainer really ).
The new Bosch would have to be much better for me to consider it, I am off to the 2015 cycle show at the nec in September and Raleigh came back to me saying that they will have the new 2016 haibikes there but no response on if they will be there to ride as of yet.
We should be seeing the Bafang Maxdrives in the shops soon. They should be pretty good.
Reactions: rippedupno1
6,514
there any prices for those ?
