The BBS01 is the easiest to install, but you lose your front gears. You'll need a top gear with 11 teeth to be able to pedal above 15mph. It will work with any bottle battery, but it would work best with one that has at least 10.4 aH. You can reach 35km/h, but in the higher gears,there isn't much torque, so you have to pedal hard to help the motor at that speed. For speeds up to 15km/h, you don't have to pedal hard. Naturally, hills reduce these speeds and increase pedal effort.
The 250w Bafang CST is a much stronger motor. The speed depends on the motor RPM, so you need to find out what that is from the supplier. You need 270 rpm for 35km/hr. I think that most 250w Bafang CSTs are about 250 rpm (31 km/h). This motor can work with a 15 amp controller and any bottle battery, but it gives much more power with more amps, for which you need a stronger battery. The wheels supplied in the kits, normally need to be dished. They're built with the rim central to the spoke flanges. You normally need to move the rim about 5mm by loosening the spokes on one side and tightening them on the other. The quality of the rim and spokes is OK, but you normally need to tighten the spokes.
The Q100 CST has much less power than the BAfang CST, and about the same as the BBS01. I think that it will have enough power for you at lower speeds, but is not powerful enough to sustain 35km/h. It's not so good for steep hills, but you said that you don't have them. You might need to dish the wheel like with the Bafang CST. To get the speed you want, a 36v battery will be no good. You'll need 44v or 48v.
These hub-motors are more relaxing to ride than crank-motors. You don't have to change gear so much, and when you do change gear, it's much smoother because there's no load on the chain.
In summary, hub-motors are a little more complicated to fit, but give a more comfortable ride. You need a 36v one with 270 rpm, or you get a 36v 201 rpm one and run it at 48v.
