My first conversion project - Carrera Subway 2
spikey
77
9
I tried all that.
When I unscrewed the cable, the plug with 3 pins on the speed sensor itself came off. It looks like that this was meant to be soldered to the sensor so I pretty sure I need a new sensor.
trex
7,703
2,671
you have an LED on the sensor. If the sensor is still working, the LED blinks when the magnet passes in front of it.
trex
7,703
2,671
then it looks like you need a new sensor.
Kinninvie
907
415
Teesdale,England
Paul does not have them on his site but I am sure if you e-mail him he would be able to source one(or a couple) for you.
spikey
77
9
Thanks guys, I've emailed Paul about this and hope he has some spare. I contacted BMSbattery and after a lengthy chat they agreed to send me a replacement speed sensor for free but the shipping cost would be $30. :eek:
8,588
Try woosh !!!
Kinninvie
907
415
Teesdale,England
trex
7,703
2,671
speed sensor is a simple device and can be repaired.
Post a picture for identification.
spikey
77
9
Try woosh !!!
Thanks, I've tried them and they don't have spares, unfortunately. They did suggest as a last resort to use a regular speed sensor and do a diy job to connect them together, but don't know how.
spikey
77
9
I've got an old bike computer that has a speed sensor. Could you show me what wires to connect to the Bafang kit.
trex
7,703
2,671
you've got the 2014 model. The sensor seems to be intact, the fault could be damaged cable. You could spend $30 getting another sensor without result.
Try to measure the voltage on the holes of the socket that this connector plugs into on the motor side. There are three holes corresponding to 3 pins, you only need to locate the ground and +5V. Linking only the 0V and 5V pins to the socket side will let you test the sensor on its own, the LED should blink when the magnet passes in front of it.
spikey
77
9
The part where you can see the pins sticking out on the previous photo has come apart and wires snapped off.
spikey
77
9
So the 3 pins are designated as
1. 0V
2. +5V
3. Speed signal
Is that right?
Would I damage the controller if I got the wires connected incorrectly?
trex
7,703
2,671
I take it that the $8 covers the sensor itself, not the cable that comes from the motor.
you still have to repair the socket first. Once done, the current sensor may just work.
spikey
77
9
Yes, $8 for sensor only. The circuit board inside the sensor is covered in epoxy. Did try to fix it but failed. Any ideas about the pin identification.
