All of the parts arrived from Hobbyking very quickly, just a couple of days.
I assembled the six 4s 5 amp packs into a "clip and lock" waterproof lunchbox.
The packs are snugly fitted together, separated by 8mm thick foam sheet, cut from an exercise mat.
All of the output leads are paralleled together and the 4s balance leads, using the balance board.
I tried it with my electric outboard in a test tank, at full speed, and it ran for 65 minutes before the lipo alarm went off, showing that the first bank of cells were down to 3v. (so that's the first cell of each 4s pack, paralleled up to 6p, via the balance board. The other three banks were still showing 3.5 volts, and they all started at 3.8v.
I've put the charger on in balance charge mode, 4s, and set the current at 0.5 amps, (trying to be very cautious here !) It's been on for a couple of hours now, and the balance display shows all four voltages at 3.52 at the moment, so presumably it's levelled out.
I'm getting a little nervous now, and having second thoughts about my 30 amp pack though.
I made the mistake of looking at some of the frightening youtube videos of just one 5amp 4s lipo pack, in a black plastic rectangular case, just like these units. The amount of flame was frightening, and I was thinking that if just one of mine went up, it would set off the other five, and I now have visions of my plastic lunchbox suddenly vaporising, and dropping through my canoe hull like the China syndrome !
I do all of my charging in the garage, with the batteries in my home made fireproof sack, sewn up from a fire blanket folded in half. I've been reading about lipos suddenly going off during use while discharging though, such as dropping below 3v.
The "12v" lithium pack is a great success otherwise, 30 a/h of usable power at around 15 volts, driving my little 12v electric outboard very strongly. The pack in the clip seal box is watertight, with the power take off as bolt studs outside the casing, just like an SLA battery. The 4.5 litre volume of the box even means that it would actually float, just.
