Maximising range
5,786
37.7 mph here. On 26" wheels I feel safe at 35-38 mph. Over that speed I am going to want bigger wheels and suspension up front.
Back on topic: use the assistance levels like you would your front derailler. On the flat and small hills I use level 2 of 5. 5 on steep climbs and 0 or 1 on downhill sections. 1 because sometimes you have a false flat section. Now that I am fit I guess I could limit myself to using 4 on climbs but 5 is more fun (lycra baiting for example :rolleyes:.
Use your gears! Get to your comfortable cruising cadence and change as often as you need to maintain that. I am always clicking through the gears to maintain my preferred cadence. Even with a hub motor cadence is the key.
Lancslass
438
266
70
Egerton, BL7 North Bolton, Lancashire
I forgot to mention, use assist at 0 going downhills, no point in having any assist on if you are doing a downhill stretch.
JohnCade
1,486
736
If you aren’t pedalling going downhill you won’t be using any battery power. Only a tiny amount used to run the BMS.
Kinninvie
907
415
Teesdale,England
Reactions: Lancslass
Lancslass
438
266
70
But I do generally pedal downhills, or at least I sometimes do, so turning the assist to 0 means I use no battery (doesn't it...?)
JohnCade
1,486
736
If you’re going downhill and pedalling while using assist in practice you will use almost no power because the motor isn’t doing any real work. You use most power going fast on the flat and going uphill. Just as pedalling on a normal bike going downhill takes almost no effort.
Lancslass
438
266
70
So might as well be in 0 assist under those circumstances?
Lancslass
438
266
70
Don't want to make the feeling worse, but we do have an unofficial 50mph club in the forum, members being those who've done over 50 mph downhill on their bikes. It's gone a bit quiet more recently.
I don't quite qualify, my latest best was just short at 48 mph.
This thread refers.
I am more likely to be joining the mile high club than the 50mph crowd on Juicy Lucy! :D:p
8,720
Got a nice rhythm to it, could be a song in it somewhere :p.
Geebee
1,256
227
Australia
Nah Lucy can do it, all you need is a steep longish hill and get into a tuck, nothing better than passing cars at speed on a dutch style bike :)
My Tonaro Esprit is a very similar bike and is surprisingly stable at speed.
