would this be easy to assemble on a king ? i mean wiring and with original parts from it .
Rob
You really need to keep the wires from the bottle battery as short as possible, and protect them mechanical,also using the correct size wires so no voltage loss etc.would this be easy to assemble on a king ? i mean wiring and with original parts from it .
Rob
Hi UK supplier £240 delivered next day and SUPORT
New 36v 36 volt 9ah water bottle type lithium Li-ion electric bike battery | eBay
Frank
You're correct. You unscrew the connector and unclip the battery.does this battery slot in slot out looks like to me you have to screw the 4 pin lead in every time or am i mistaken ?
All the parts are standard. If you chuck the original battery, you need somewhere to install the controller. Those tool-bags that clip under the seat or in the frame are OK. Some people mount them externally with just a bit of sleeving over the connectors. Hidden under a rack is a good location like that. You van also get a controller box from BMSBattery, but it's a very tight squeeze to get all the connectors in. If you have a motor connector near the motor, I'd solder the motor hall and pphase wires directly to the controller, and cut of any unused wires and connectors to make more room.would this be easy to assemble on a king ? i mean wiring and with original parts from it .
Rob
