Hi
Just wondered if anybody had any thoughts to a problem I have with kudos king, last time out and today the bike lost power, ie the bike cut of and control panel went off.
Pressing the on button, on the control panel did nothing to restart the power, turning of the key on the battery and then back on, enabled the control panel after pressing the on button, this happen a few times during the first few minutes of using the bike then all is ok, i did 25 miles without a problem.
Do you think this could be the 36v control box, once getting a bit warm the fault corrects it self. I have looked for loose connections and sprayed the connectors to see if that helped
the first time it happened but it hasnt helped. Any thoughts please.
