Kit list for my trike - Opinions appreciated
johneb
88
5,786
At long last, I've ordered the motor & controller, etc. I'm now considering going straight to 48v and so I'd be grateful battery advice, please.
I'm considering this: http://eclipsebikes.com/product_info.php?products_id=147
But is it really worth over £130 more than this?: http://www.pswpower.com/peng/iview.asp?KeyID=dtpic-2017-7M-D4MX.9PERW
Any other suggestions appreciated. I'm looking to get decent range, so at least 13ah?
The Samsung cells are low discharge but the LG ones are 10A.
Reactions: johneb
johneb
88
Thanks AK, but can you enlighten me? Does that make one better than the other, or simply offer different characteristics?
5,786
Reactions: johneb
8,593
29E fairs a bit better then the MG1, the only real world graph I've seen for MG1 was on ES.
Generally SAM's are a better bet then LG's
MG1 although 10a rated is a poor medium rated cell, voltage and ah crashes/sags terribly above 5 -6amps, though delivers good mah at low amp draw.
Reactions: johneb
johneb
88
I still have much to learn!
OK, so hauling around 100kg (trike + me) with a Q128C (201/260 rpm 36v running at 48v) in a 20" wheel, what sort of continuous & peak discharge rates should I be looking at? As I've said before, most of my riding will be on no more than gentle inclines, but I'd like to be able to tackle the odd steep hill (Thinking of a favourite route in Wales - up to 7% for a couple of miles). The motor would (hopefully!) be doing about 75% of the work.
16,974
you don't need much to tackle 7% gradient with 100kg weight.
That Q128C running at 48V 260 RPM on 20" wheel, I'd guess 15A so any decent cell would do it unless you want to ride at higher than the legal speed limit.
* 675W mechanical, 80% yield.
Reactions: johneb
8,593
Depends on the controller amp rating, though invariably if only using say in pas 3 then amps draw will be approx 40-45% of the max rated amp draw.
A 48v system with 15a controller is capable of putting out 720w average and at 20a 960w, on a fully charged battery a bit more 780w & 1040w.
The more cells in parallel then the better they share the amp load.
Tops cells are Panasonic GA, Sam 30Q, Sony VTC6 & LG MJ1 for 3000 - 3500mah 10-15 amp rating.
For higher amp rated cells then 2500mah cells are Sam 25R (Green), LG HE2 & Sony VCT5A.
Best selection of cells used is from this lot in Germany, also as referred to by AK as well.
http://enerprof.de/product-category/batteries/ebike-and-pedelec-batteries/36v-battery-li-ion-37v/softpack-2/
For 30Q try Eclipse or for more bespoke diy route or Jimmy at BGA/Insat.
Reactions: johneb
