Insat battery voltage sag
danielrlee
1,396
725
Westbury, Wiltshire
torquetech.co.uk
masochist :)
what can it do more than a cheap KT LCD?
There really is too much to list. Some of my favourites include:
Temperature monitoring;
Thermal rollback;
Throttle & PAS ramping;
Throttle input & output remapping;
Simultaneous speed, current & power limiting;
Dual analogue & digital auxiliary controls;
Custom presets;
LVC power rollback;
Diagnostics display
The Cycle Analyst has come on a long way in six years. Maybe you should check out some of the changes since you last used one.
Name one thing that it can do that I need.
Two of my CAs are V3. I bought one to go with a torque sensor before I realised that torque multiplication systems are the worst way to get power to the motor and torque sensors are ridiculously heavy.
The other problem with the CA is the amount of wiring you need.
danielrlee
1,396
725
Westbury, Wiltshire
torquetech.co.uk
Sorry d8, my crystal ball is broken at the moment.
I don't think it generally does increase the amount of wiring - there's only a single cable that runs between the CA and controller after all. It does affect where the wiring goes though, since all inputs connect to the CA, rather than the controller. Only when you get into some of the advanced functionality do you need any additional cable runs.
Reactions: Dave.ah
