Hate to say it (and I may be wrong) ... but looking at your climb profile I'd be astonished if you were only getting 1:0.7 assist. If you are and also managing those speeds then you must be a strong / fit rider working reasonably hard throughout the ride.
I'm small and fat but I do hike up the mountains and have been riding my MTB for years. I do have strong legs but I can't say I can compare them.
On the steep climbing it's an odd thing - I'm currently thinking that motor capability max-out can occur far lower than potential theoretical assist. You only have a 350W (restricted) motor and therefore I'd expect its capabilities to max out in that terrain at pretty low speeds (9-12mph max on a prolonged very steep climb). I'm guessing therefore you may not notice that much more power than you already teased out of the motor in a higher assist mode - it might just stop you stalling out so easily if you decreased your efforts.
Yes - I wondered that which is why I tried the higher power settings at several different times.
At Manifold in April I tested 2 bikes.
I've included the links so you can compare my speeds on two different bikes.
1 KTM eRace 650 (Torque Sensor) Panasonic Rear Hub Drive
2 KUDOS Arriba (Torque Sensor) 8Fun Rear Hub Drive
Assumptions/Facts
I wanted to test the bikes under the conditions under which I might use them i.e. knackered.
Thus I did a 7 mile hike first including 700m of ascent.
On the bike I carried 2 full water bottles with me.
I weigh about 14.5 stone.
On each ride I approached the hill with no assist on.
The route was 2.61 miles from the Tea Rooms up to Wetton and back with a 20 second ish stop at the top. The hill is about 10-11% no more through the majority of the climb; the average through the climb is about 7.5%.
Comments:
Terrific bike, torque sensor was magnificent and gave a very smooth ride. Beautiful gear changes and lovely smooth rolling along without assist. With assist coped with the hill easily and an enjoyable climb. Very enjoyable descent max speed 39.44mph w/out pushing brakes were excellent.
Ride Link:
Cyclemeter - Cycle - Apr 13, 2013, 11:59 AM
Comments:
Good bike, torque sensor was solid but a bit lively when setting off. Gave a smooth ride but it seemed to me that the motor kept cutting out for a micro-second every now and then. Good gear changes and smooth rolling along without assist. With assist coped with the hill easily and an enjoyable climb apart from the glitches mentioned earlier. Very enjoyable descent max speed 33.58mph w/out pushing brakes were good but I was wary of them - hence a slower descent.
Ride Link:
Cyclemeter - Cycle - Apr 13, 2013, 12:20 PM
(Note the drop in speed at around 1.35 miles.
I might be wrong on that - someone will no doubt tell me if I am. But there's only so much power a motor has to offer and it being theoretically capable of 2:1 or 3:1 assistance doesn't mean in practice that it can. I'm very interested in finding out if this is correct - because it may answer some of the questions I was going to try and have a challenging long test ride of the Neo to find out for myself
I tried Garry's Neos at Wetton and it sped up the hill - I didn't feel the same today. It would be good if Garry reads this conversation and chips in as he's very experienced with these bikes.
Rather than do a long ride to test range - if you can manage try the different power levels in as flat a terrain as you can find. You should notice a big difference in acceleration. Then try to climb a single steep slope and play with the gears you use in the different assist modes to see if that makes any difference. I don't understand PAS hub-drive bikes much as only have a throttle on mine. Although I understand the motor doesn't drive through the gears, the gearing chosen still matters a lot as it makes a difference to what I'm usefully adding to the motor - both in terms of top speed and effective climbing.
I'll perhaps try that this week. As for the gearing, it's something I do naturally, I have more or less the same gears on my MTB. It is natural (on the Neo) to go UP a gear to make the motor do more as it senses the harder effort I'm putting in. It's all fascinating. I'll be interested to see what you make of the Wetton ride speeds compared to the Neo rides.
