I opened up the shed and I could have cried.
Look at what my negligence has done!
Just off to oil and then take for a gentle conciliatory ride
I sometimes feel that my informative videos are wasted here.Oh, the shame!
Or put some oil on it and go out for a ride ?soak it in some coke as it has a ph of 2.5 for 24hrs then clean and re lube it.
You should think your self lucky. The following corrosion is an example of what begins to set in after leaving the bike for a couple of hours of riding in my neck of the woods.I opened up the shed and I could have cried.
Actually the comment was in response to the question which is worst.. putting away dirty or clean but wet into a garage where it won't dry.You should think your self lucky. The following corrosion is an example of what begins to set in after leaving the bike for a couple of hours of riding in my neck of the woods.
The comical thing about seeing your bike though, is that only about a week ago, d8veh was suggesting to gubbins that putting a bike away dirty is fine. When I read the comment, I remember thinking wtf.
This. It's the real thing..soak it in some coke as it has a ph of 2.5 for 24hrs then clean and re lube it.
Totally agree.Her place is in the sewing room, yours is in the wrong. (Well mine is)
The dog gets the middle of the bed. Apparently I hog the edge of the bed!(Totally agree.
I was emboldened with scotch last night, there is as much chance of getting the bike in the house as the dog sleeping outside!
Just turn the rear wheel backwards, does the same as back pedalling.I have a chain cleaner that slips over the chain and cleans it by back pedaling... but can't back pedal my ebikes...
