I’m new to ebikes.
6,693
the chain is to short so add a couple of links to it as if the rear mech is maxed out like that you can snap the chain or rip the mech in half.
also those spokes seem to be bent in ways that dont look right to me.
3,345
Guerney,
The battery is coming on Monday. I’ve got a comfy saddle to put on, then I’ll be on the road!
Regards,
Bill.
You've got the new buyer advantage: If something snaps, it's up to Fiido to repair or replace. Adding links to try can't do any harm. The easiest way to add links, is using masterlinks - that way the chain won't snap if you've connect links badly using a chain tool (easily done - I cracked a front tooth once a very long time ago, when a chain broke while going uphill and I landed face first), leaving it weak. Masterlinks are also easy to remove if required.
Various Masterlinks on Amazon
3,345
Maybe that's normal for Fiido? We need @cyclebuddy , who owns a similar Fiido. Here are photos of his spokes:
3,345
Guerney,
Regards,
Bill.
Is there a chain tension adjustment screw on the derailleur? I's try unscrewing that first, before considering adding links.
49549
6,693
that is the b screw it adjusts the distance between the top jockey wheel and the mech distance wise the other 2 are for hi low adjustment but they look bent as well. o_O
3,345
Surely he can't have been sold a completely bent bike? Do you have Central Serous Retinopathy like I have? Look at this Amsler grid, follow the instructions - you may have kinky eyes like mine, where one eye can show straight lines kinky, but when both eyes are looking, the brain combines the images and straightens them out ;)
6,693
:cool: all level atm but just done 5g of magic m loads up may hill class a for free o_O
Reactions: guerney
6,693
1060 6gb 4k all monitors 3 dp and tv hdmi
Reactions: guerney
3,345
Yep, that could burn your maculas for sure. Add some ambient lights to even it out? CSR is the new RSI for IT workers.
3,345
Guerney,
Regards,
Bill.
Angle on my highest gear (mine's an old, used like mad bike) - your required angle may vary:
49551
6,693
clean it you tramp wd40 in all pivot points after clean new cable as that's fooked and should shift much better ;)
sram xx1 good as new cleaned with a jet wash it felt like broken glass moving any of it so had to strip it down and charge the seller 40 quid for my effort pmsl :rolleyes:
if i put that on my bike as is it was it will be totaled in no miles at all as grinding paste in every pivot point.
Reactions: guerney
3,345
clean it you tramp
:D
But it'll just get dirty. It can't get dirty if it's already dirty. Suits me fine, because I'm a very dirty person, also lazy - simply chucking Hypoid 90 over it all, suits me fine. Works perfectly, saves time.
6,693
santa has a upgrade ;)
Reactions: guerney
3,345
Santa, I've written to you many times before every Christmas. This year I'll use Klarna.
6,693
Reactions: guerney
6,693
id not buy a new one esp gen 4 smart motors gps will end all dongles.
just make it go 500 miles at that speed,
Reactions: guerney
3,345
Cheers for post that amazing vid - I searched for it a few weeks ago to send a friend a link...
He wobbles in a worrying way for a split second somewhere in that video - I'm not surprised he fell off and won't use large engined bikes anymore.
Downloaded it through the Opera VPN... ;)
6,693
