How many people are using there e-bike off-road?
6,733
i know just so others can find them m8 knew i seen them somewhere ;)
you got 16t same as mine? did not need the crank puller just came off undoing the bolt.
EddiePJ
4,632
4,013
Crowborough, East Sussex
www.facebook.com
Just clocked that I'm staying at the below overnight on my way down to Switzerland.
It would be rude not to go out for a relaxing evening play in the local woodland. :)
I might have to contact this lad to see if he lives in the area and ask if he could show me some of the routes. I've driven through the area few times, and the scenery is fantastic, but being able to ride it should be brilliant fun.
If I can find the exact location, might also take another little detour the next day, but haven't run that past my much better other half. ;)
I'm already getting impatient, and just want to go. I've spent a bit of this evening buying/adding a few more spares to the already comprehensive list that I always carry. It's going to be a long five week wait. :(
8,843
Went out for a ride this am and covered 53km/33m on road and off road on the Cube BBS. A few teething problems to sort out, only 2 miles in the chain snapped I had previously added 6 links so may have not fitted a link pin correctly, luckily my cheapo Chinese multitool with chain link remover proved in valuable and saved the day ( must remember to add a dozen spare chain links to my bike kit), the magnets for the brake cuts offs moved I had used an Araldite product but this didn't hold them to well so need to find something better to glue them on with and finally on the homeward journey one of the Hayes 9 HDB's dumped its fluid from the lever as one of the master cylinder bleed plugs let go, I will repair and reprime the lever/system but in time I may well replace them with a set of Shimano's BR445/6 or BR395/396 which work superbly on my other bikes. The wide comfy saddle was not as comfy as it looks so this will be swapped over to the Charge.
On the plus side the BBS(now over 1k miles)worked well smoother and less of a raging bull which the pas on the Oxydrive cst can be when going offroad also the throttle and power response felt better, with 9 levels of pas on the BBS lcd its easier to select to go up or down depending on the extra power you need. Battery wise the BBS is better with battery consumption the usb 15ah battery still had 2 of the 4 battery indicators showing on the lcd after the 33miles where as the OXY's battery is empty after 25 miles.
8,843
Just watched the video of the swiss guy he's nuts, very nice control of the rapid free style downhill though. Don't do it Eddie:eek:.
Reactions: EddiePJ
6,733
whats the main German haibike/ebike forum called??
6,733
ed i got a bit of a problem, i got the spanner today and changed over the sprocket to the 19t but when around 1820 mph and over seems the motor is grinding inside? or thats what it feel like.
looks like the sprocket is a bit thinner than the haibike one so bit closer to the inside when i slide it on is all that i can think is making the motor not happy with it.
RobF
4,732
2,312
Much as I like a clean drive train, yours looks a bit dry so worth trying some chain lube.
The new sprocket may have messed up the line to the idler sprocket, although I would be surprised if that made much difference.
I take it you are using one of the smaller cogs at the back to achieve the speed.
This also puts the chain line out from straight.
Worth trying the bike at a high cadence in whichever gear it is that gives the straightest chain line.
Reactions: soundwave
6,733
i did lube the chain after that pic but made no difference tbh but it just dont feel right as something is out of sync.
i put the old 1 back on and its fine now but the gap between the sprocket and the motor is double that of the 19t sprocket. as that is near touching the inside of the motor when it was on and thus getting the grinding feeling from the motor.
it might be that i need a washer in the idler sprocket so it can move tho i dont know ill stick it back on tomorrow n take some more pics.
EddiePJ
4,632
4,013
www.facebook.com
Just to add to what Rob has already said, is there a possibility that you had knocked the plastic cases, and that it was just a rubbing or even a simple resonance noise from the casing?
When you re-fitted the 16T, the cases might have then settled back into place without you even noticing.
If it makes the same noise tomorrow, remove the cases altogether and then ride the bike.
6,733
i dont think it was the case rubbing as i felt it when peddling above 18mph like it was grinding the bearings or something.
but ill take the case off in try it again anyway and take some pics.
thanks for the help ;)
6,733
the spanner was just under 20 squid delivered from Germany and was here in 4 days if anyone needs 1.
Reactions: EddiePJ
Cuthy
9
We have just started doing off road tours of forest trails and tracks in the Isle of Man.
We use the Bergamont Roxtar 8.0 for the tours. Bosch performance line motor with manitou marvel air sprung forks. , shimano SLX 10 speed drive train and hydraulic Shimano BR-M506 disc brakes as standard.
We have started an electric bike business called Green Wheels in the Isle of Man. Not sure if I'm allowed to add website but will do www.greenwheels.im
The more people try the electric bikes the more they will start to catch on. I just love it!:)
6,733
thanks ed did find it in the end ;)
going to forest tomoz so did not retry the sprocket today as was p ing it down all day.
ed if your bike is in turbo mode how many miles can you get out of it?
min max effort so say peddling, shows 30 miles on mine after resetting it.
EddiePJ
4,632
4,013
www.facebook.com
No idea I'm afraid.
I Hardly ever use or need turbo, and just generally use either no assist, eco, or tour. Even doing this, it's a struggle to sometimes get past the mid thirties.
If I use sport or turbo, I guess that would probably kill the battery after 20 miles of riding.
6,733
you sure as i can get more than 20 with my dongle on it,tho thats on flat paths ect.
guess ill find out think ill leave the dongle off it as never seen how far i can go with out it up down hills ect. i thought about 20 with using it tbh. but ill take it with me if any batt left at the end.
and its event day as well lol
Calendar Of Events
09:00 - June 21st, 2015
MIJ Downhill
The only summer downhill race in the Forest of Dean! Get your entries in. For more details see the MIJ downhill website or facebook page.
6,733
whats the most miles you can get from it in in eco then? you must have legs like tree trunks lol
says 89 miles on mine in eco, can you get that far?
6,733
Mine says 81 in Eco and have managed 66 miles on Eco then cranked up to high for about 5 miles and still had 11 ish miles on Eco after I got home
i should get 30-40 miles then if i try keep it in tour/ sport for up hill then with out dongle that is.
wish i had another batt now to compare with and with out dongle batt usage in diff modes.
