How many people are using there e-bike off-road?
6,684
Order Complete! Congratulations, your order has been placed. Thank you for shopping with Bikegoo (see order summary below)
ill pm you if i get stuck with it ;)
Reactions: EddiePJ
6,684
no problem ;) do they sell that spanner to take off the lock ring ?
6,684
that's the 1 im looking for
6,684
yes but im not paying that ill use a screwdriver and tap it round with a hammer ;) its not that tight
6,684
that was fast got the crank puller already first thing in the post ;)
Reactions: EddiePJ
6,684
ed could you charge the batt while riding it with the power off?
6,684
well i got the new sprocket and had a go at getting it on but i cant get the lock ring of the thing.
tried to tap it round with hammer n screwdriver but just chipped some of the plastic of it so stopped.
cant get a grip of it with adjustable pliers either.
so looks like ill have to get a lock ring tool/spanner to remove it without damaging it any more.and get a metal 1 to replace it with.
i also did not need the crank puller as it just came of undoing the Alan key bolt as it don't come out of the crank arm so that was easy to remove and put back on ;)
baeb also said i can get the dongle with the x3 firmware if i wanted it for 75kph tho will have to buy another 1 as mine is the x2 50kph one.
6,684
RobF
4,732
2,312
The lock ring is a left hand thread.
Reactions: soundwave
6,684
i know that ;) im just getting the metal one for it as i will need to keep changing it anyway.
i prob could get it off but if i brake it doing so ill have no bike to ride in the mean time.
also seeing if baeb will unlock the dongle so there is no cut off speed
