Home made pedelec
4,230
I've been thinking about this and have realised that the reason tadpole trikes have the pedals stuck out in front is to bring the centre of gravity just aft of the front wheels. As you move the rider further aft then the effective wheelbase decreases and the machine becomes unstable. A four wheeler doesn't have this problem. This is probably obvious to everyone else but it wasn't to me! A four wheeler has the problem of needing a differential which isn't easy or cheap. So I was wondering .....why not make a 5 wheeler with the motive power provided by a 5 th wheel between the two rear wheels? The outer wheels would just be on stub axles fixed to the chassis. There was an extra powered wheel made at one time for push bikes, it was hung on one side and the engine was in the hub.
You might get some ideas from this one. He made a limited slip differential out of bike freewheels in another video; however, I think he made a mistake with the brake because the wheels can still freewheel when the brake is on, and you can see that he didn't have a back brake when testing. You'd need wheels with individual disc brakes fitted to the hubs, then mounts for the calipers.
thelarkbox
1,676
523
oxon
Sounds like a set of my first bike stabilisers? , lift them out of the way at speed and benefit from 2 wheel at speed stability even to improve cornering etc.. ? is it gyroscopic stability that keeps a moving bike stable??
Brain fart excuse me..
Would only require the single 5th rear wheel to have brakes too.
matthewslack
2,595
1,672
Why not a three wheeler tadpole with wide rear stabilisers? They only touch down to prevent rollover.
The first reg to laminate or have linked on your phone, im old skool and have a laminator ;)
Is the definition of EN15194,,
The second is the amendment or ruling that says 4 wheels is still a pedelec and covered by epac regs.
As to what that is specifically?? I dunno?? but if no one here can cite or signpost you ?? a locally relevant legal forum might be worth a visit?
This is page 2 from the 6th April 2015 amendment to the EAPC regulations:
See item 3 (b)
(3) In regulation 3—
(b)for “bicycles and tricycles”, substitute “pedal cycles with two or more wheels”.
So you can have as many wheels as you want.
Presterjohn
35
I've been looking further into the differential question. Early cyclecars did not usually have one, instead they used two belt drives to the back wheels. A belt will slip whereas a chain will not so I guess this solved the problem in a simple and cheap way. I could do the same, mounting the rear wheels on stub axles [using the bearings in the wheels] and a vee or polyV belt drive to each wheel from a countershaft which would carry the gear cassette, freewheel and derailleur. The polyV pulleys can be quite small, I have used them on machine drives with great success.
AndyBike
1,777
767
I like the fact its got some curves on it. Many of these type of builds come up with something that could be mistaken for postman pats van.
Presterjohn
35
Hi, this is going ahead. I'll post some pics when I get some bits made. I am going to make it just pedal to begin with rather than shell out a load of money on a mid drive motor. I am wondering about the braking and would appreciate some input please. It seems that most tadpole trikes have independant front brakes - is that right? Any ideas how I can get 4 brakes working with only two levers? I am using disc brakes [ I have got the wheels] . I was thinking of cable brakes.
matthewslack
2,595
1,672
I wouldn't worry about 4 wheel braking to start with, put that on the enhancements list so that it doesn't 'slow you down'. (Didn't see that coming!)
The legal requirement is two independent braking systems, not brakes on all wheels.
My tadpole has independent front brakes which work very well, and no rear brake, except a parking brake.
I would concentrate on powerful front brakes, big rotors, four pistons and hydraulics.
There are levers that operate two brake calipers, I haven't used them.
Presterjohn
35
Thank you. I'm looking at hydraulic brake kits. I am thinking of using an old Peugeot bike frame I have which I will cut and build into the vehicle. This will get me the bottom bracket and derailleur mountings. I intend to fit a rear hub [ without a wheel] and take the drive from it to twin pulleys to the back wheels. I have a question about the bottom bracket. The one I have is 68mm wide and the cups that screw into it are right and left hand threaded and are 34.75mm diameter. Will this frame fit a mid drive motor kit?
matthewslack
2,595
1,672
That sounds pretty normal: 68mm is a standard width and the bore is around 33mm, so yes sounds fine.
Presterjohn
35
Thanks Matthew, I'm not so sure. The thread looks different. It looks like a coarser thread than the bsa ones. I managed to get apart another rusty bottom bracket and it wouldn't screw into the Peugeot threads. I read somewhere that they are not all the same. Also the square taper spindle has male threads on the ends so they would need nuts to fit the cranks.
4,230
None of that is relevant when you fit a crank motor because you chuck all those things. The only things that matter are the length and inner diameter of the tube. The BBS01 shaft diameter is the same as any other at 33.5 mm diameter. 68mm long is standard.
Presterjohn
35
Ok, that's interesting. At the moment I just want to make it without pedal assist. What kind of new bottom bracket can I buy that will fit? I haven't got any cranks or chainwheel etc. I don't want to spend too much on this because I'm eventually intending to buy a mid drive unit.
4,230
A standard BB (Shimano or BSA type) is 1.37″ x 24 threads per inch (approximately 34.8mm diameter). All other typres are close to that. Some older French bikes have 35mm dia and 1mm pitch (25.4 TPI), other bikes have 26 TPI. If yours has 24 TPI, you'll be OK.
The nut or bolt at the ends makes no difference. A new BB comes with the nuts or bolts.
Presterjohn
35
Hi, i've been making some progress so here are some pictures. As you can see I've decided to make it a 3 wheeler because I don't want to be the one to test the law out regarding whether a quadricycle is legal. I am incorporating lugs etc to make it easy to convert it to a 4 wheeler at a later date.
Reactions: thelarkbox
matthewslack
2,595
1,672
Front end geometry will be hard to live with.
The steering axis needs to point at the tyre/road contact patch, otherwise there will be severe bump steer and other unpredictable unintended steering inputs.
That needs a significantly non-vertical axis in the front view, and usually slightly non-vertical on the side view too.
Castor is the name for one of those angles.
My trike has MacPherson struts, just like car suspension, with a single lower wishbone and anti roll bar.
It might be useful to fit wheels and have someone push you around a carpark to get a feel for it.
2,858
matthewslack
2,595
1,672
I completely misread that; I read it as referring to web based computer art.
My art is exceptionally hard to live with!
Presterjohn
35
Ok, i've got my 3 wheeler going now. The steering is actually very precise [ I'm using wire and bobbin]. it drives hands off in a straight line . I've got a bit of toe - in and the axles trail the suspension mounts. I will alter it in line with your comments if i need to but I've got a more pressing problem with it. I found by experiment that i needed shorter cranks so i've ended up with 152mm. Also by experiment i couldn't move it so i now have a 24T chainring and that is fine. i went with a rear hub motor - it came with the wheel and was very cheap from PSW power. However the hill climbing isn't great so I am thinking of using a hub motor as a mid drive. I have a mid drive sprocket anyway to shorten the chain length. It would be a simple matter to fit a hub motor there with a fixie sprocket to the rear wheel and derailleur so getting the gearing down for hill climbing. I can still mount a freewheel on the hub as a locknut. [ I got this from an old forum Aussie posted. The snag would be that there would be no speed control so it wouldn't meet the regs. Is there any way to fit a speed control sensor?
matthewslack
2,595
1,672
Steering issues will be masked when going straight ahead by symmetry.
What happens in a tight bend with a bit of speed on? What happens on a straight line but across a slope or camber? What happens if you go hands off in those situations?
If you push it sideways when stationary, how easily do the wheels move around the steering axis?
Speed sensor should be fixable, but requires wiring mods. Fit an external wheel magnet and sensor, and connect that instead of the motor's internal speed sensor, and set the configuration parameter correctly. You will need to access the speed sensor wire in the 9 way motor cable to do this.
