Not quite!I recall Flec saying the eZee Torq bikes are probably amongst the best climbers available...
I actually agree with you Drago, I think Wisper is overpriced for the components they use. The bike has a large battery and good motor but all the other bits and pieces are simply poor components. Shimano Alivio dérailleur its a probably best part they used. the front brake (Tektro or something) is the one of the most basic brakes i ve seen. All othe rparts are the same basic bits.Trying isn't all that simple. My nearest dealer is 35miles away and there I tried a Wisper. Most of the multi franchise dealers are much further away. I don't want to go ahead with the Wisper,which try as I might cannot justify their price for the components used, if I can get a better allrounder that is worth that type of money.
Can you name one then please, as I am in the market for a new E Bike with decent hill climbing and range. I don't like the Panasonic crank drive though I wanna throttle bikeI rather think you can get the same quality bike for less, that is my opinion.
On the other hand they do provide good service but does not mean that other makes don't provide a good service. I rather think you can get the same quality bike for less, that is my opinion.
Yes, look at for example Ezee Forza, the Gadget Show's winner. Comes now with the 14Ah battery, Shimano Deore gears, 9 speeds, Shimano disc brakes front and rear.Can you name one then please, as I am in the market for a new E Bike with decent hill climbing and range. I don't like the Panasonic crank drive though I wanna throttle bike
The Forza is of comparable price at £1450 and only comes with 1 year warranty...just sayin'Yes, look at for example Ezee Forza, the Gadget Show's winner. Comes now with the 14Ah battery, Shimano Deore gears, 9 speeds, Shimano disc brakes front and rear.
It's just one example, I'm sure you can find even more of those.
It costs more then a wisper 905Yes, look at for example Ezee Forza, the Gadget Show's winner. Comes now with the 14Ah battery, Shimano Deore gears, 9 speeds, Shimano disc brakes front and rear.
Your commute is a bit longer than mine and you have more in the way of hills. I find the 905 has a limited range of gears (not enough difference between top and bottom) and requires quite a bit of maintenance, so I'm looking to upgrade it to one of the new 906 Alpino when they are available in a couple of months. The components seem better on the 906 and it has a wider range of gears from the Alfine hub which will also get rid of the labour intensive derailleur system. It's also got full size wheels and a bigger frame which will be nice.Trying isn't all that simple. My nearest dealer is 35miles away and there I tried a Wisper. Most of the multi franchise dealers are much further away. I don't want to go ahead with the Wisper,which try as I might cannot justify their price for the components used, if I can get a better allrounder that is worth that type of money.
When I visted OnBike I tried out an Emotion and loved the bike.
That looks like a nice bike then, the 9 speed cassette has a better range of gears and it has decent components. Not enough to tempt me away from the 906 though as it's still too small.Ezee can supply a 14amp battery - I have one. OnBike will supply this. It works out more efficient that the 10amp.
