Help with finding an ebike repair shop
nightrider
134
43
70
is there not the electric transport shop in York city, have not checked out for a long time, might be gone by now, but worth a check.
Wicky
2,823
4,011
Colchester, Essex
www.jhepburn.co.uk
Repair Cafés are free meeting places and they’re all about repairing things (together). In the place where a Repair Café is located, you’ll find tools and materials to help you make any repairs you need. On clothes, furniture, electrical appliances, bicycles, crockery, appliances, toys, et cetera. You’ll also find expert volunteers, with repair skills in all kinds of fields.
Visitors bring their broken items from home. Together with the specialists they start making their repairs in the Repair Café. It’s an ongoing learning process. If you have nothing to repair, you can enjoy a cup of tea or coffee. Or you can lend a hand with someone else’s repair job. You can also get inspired at the reading table – by leafing through books on repairs and DIY.
Clive Belfield
28
Have you carried out a Mosfet test on the controller to see if one has failed or failing ? The controller has many components and is impossible to check except for the mosfets and a visual generally for anything that looks damaged like a resistor.
Disconnect the battery and probe between the controller v- and each of the three phases using the 200k scale all three results should be the same any one widely different means a duff mosfet /controller also check between v+ and the phases all results should be the same, the latter may only register infinity or one which is fine if ay read zero then you have a duff mosfet.
Hi Nealh, apologies for my lack of technical knowledge but what is a mosfet?
30,666
Thank you, very kind of you but what does it look like and what does it exactly do?
The appearance can vary to a degree but could be like one of these, there will be several of them, most often on the perimeter of the circuit board.
Their job is to transmit the pulses of electrical current to the phase windings of the motor at the correct times dictated by the controller.
Clive Belfield
28
Thank you. I assume it is inside the controller. Are they replaceable or do I need a new controller?
30,666
Yes they are replaceable, about the only part of controllers that's worth replacing. However they need to be tested to ascertain if one is faulty. If as it appears, you have no electronic knowledge or experience in replacing soldered in components, it's probably best if someone with the relevant experience tests and if necessary replaces.
I realise that would take you back to square one of seeking someone to do just that but I can't see any other practical way. Perhaps the repair cafe suggestion at the top of this page is a possibility of finding that help?
Alternatively Electric Bike Sales boasts it has experienced e-bike technicians in all it's shops and they have one at York. Information Link
Clive Belfield
28
Yes they are replaceable, about the only part of controllers that's worth replacing. However they need tested to ascertain if one is faulty. If as it appears, you have no electronic knowledge or experience in replacing soldered in components, it's probably best if someone with the relevant experience tests and if necessary replaces.
Alternatively Electrcic Bike Sales boasts it has experienced e-bike technicians in all it's shops and they have one at York. Information Link
Thanks flecc for your comments and suggestions.
