help on buying brake pads
8,564
I wont have a clue how to fit those, to my bike, so you say no cable so how do they stop the bike. is it all done by oil or what ever
It's simple undo your old brakes and simply bolt on th new ones.
Hydraulic brakes on a bike work much the same way as on a car , except one has a lever to apply the brake force pressure instead of a foot pedal.
Hydraukic brakes with callipers come already primed with synthetic fliud ( don't buy ones that use DOT 4/5 brake fluid) .
Measure the the length of the old brake outer cable and buy hydraulic brakes of a similar length.
Hydraulic with synthetic fluid are pretty much maintenance free unless one has a a leak or messes about with them when they don't need to.
P.S
In #1 imv one has left it a bit late to change the pads , I would have changed them over well before the conditon yours are in.
Always have spares in your kit/chest so one isn't caught out.
I 'm still using a supply of pads I bought 6 or 7 years ago from AliExp , I bought a job lot /bundle for £1 a pair .
billyboya
1,137
90
73
uk
P.S
Well I will wont bother fitting Hydraulic brakes for now, as Ive ordered pads, but will buy a few more for another time they go down
these are the pads I need but cant seem to find them on Aliexpress
8,564
Raboa
792
298
52
: Compressionless cables ? They do not compress (as much) end to end. So when you apply force to the brake lever more of that force ends up actuating the brake rather than shortening the overall length of the brake outer cable.
billyboya
1,137
90
73
uk
Oh so its easy to replace the old outer cables to these then
8,564
By the time one has spent money on outer cables and inner wires etc,etc, price wise one won't be far off getting entry set of hydraulic brakes for much the same money.
Bicycle Hydraulic Disc Brakes Front Rear Calipers Set for MTB Mountain Bike Left Right Brake Lever Kit with 160mm Disc Rotor - AliExpress 18
This set even has brake cut offs with SM plug , if the plug isn't compatible just cut both off and solder wire to wire .
XOD Ebike Bike Hydraulic Disc Brake Electricty power control shifter disc brake hydraulic bicycle brake SM Plug - AliExpress
Both brake sets will use the commonly used B01S designation pads found on many entry brakes.
billyboya
1,137
90
73
uk
I may try these another time, but for now im ok with the normal brakes. so these Hydraulic Disc Brakes uses oil then not a cable wire, as im a bit confused never known these brakes before, so that SM plug goes to controller for the brake lights.
billyboya
1,137
90
73
uk
Thats good, I must be getting old lol, as my 1st bike I had was block brakes, which used to rub on the rims. then they have brake pads with cable, now they have Hydraulic brakes, whats next probably a remote device on handle bars what you press lol.
  • Autobrake Bicycle
    A system that uses a camera and sensor to detect stop signs and trigger the brakes if the rider doesn't slow down. It also has a button on the handlebar to manually turn the autobrake off.
8,564
Hydraulic brakes on bikes os nothing new , they have beeen around for at least 20 years.
Once hydraulic brakes are used one will never want to return to crappy cable brakes .
billyboya
1,137
90
73
uk
Well I must be behind on bike brakes lol. Wow Hydraulic brakes been around for 20 years never knew that. Anyway just a question regarding bolids brakes would anyone know if you can get this black plastic screw as seems I have lost it somewhere
billyboya
1,137
90
73
uk
The clip is to hold it together until it is installed so you don't lose everything again before you install it.
Oh so the spring is inside then. So clip is just to hold the spring ok many thanks will order some
