Help needed
  • Start date
As you might know, I've got the Woosh Sirocco CD on loan from Woosh. Someone asked about the internal drive system, so, as I had a bit of time to spare, I decided to open the main part of the motor to see how it worked and get some photos. The cover was a bit stuck, so I gave a good heave and as it came off, the bike fell over and some of the internals fell out. There's lots of spacers/shims etc and a rather complicated clutch, and I cant figure out how the correct assembly sequence.
The motor is made by TCM, but I can't find any trace of them from a Google search. Does anybody know who/where they are so that I can ask them for a schematic. I've got to get this thing back together before Redbridge or I'll be in Hatti's bad book.
16,884
Hmmmmm. BIG problem D8veh.
Already run out and you've just scuppered our demo.
NOW what are we going to do?
I am going to have to put my thinking cap on.
Hatti
I was up very late last night (early this morning) and I've tried a few permutations. I managed to get it back together, but the pedals go round with the motor now, so something's not quite right. You can ride it like that, so you could have something for Redbridge. it's just that you can't stop pedalling.
johnc461165
546
22
WN6
Dave did you take any photos of the parts, any more info on the motor other than the name
[NoLongerRegistered#9756]
23
found this on a tonaro thread.. ok can't post the image... but it's on the 2nd post
Endless-sphere.com • View topic - TONARO Pedelec Kits
tbh not sure if it'll help but *might* be of use??
I'm sure i saw a photo thread somewhere where someone had dismantled a tonaro engine but canna find it :(
as for the pedels going round that'll be the clutch? - maybe something in the wrong way round?
very best of luck :)
trex
7,703
2,671
does it have something like this unidirectional sprag bearing?
Croxden
2,134
1,384
North Staffs
April Fool
funkylyn
3,172
27
South Shields, Tyne & Wear
Pull the other one Dave lol :D
Lynda :)
jazper53
890
18
Brighton
Ah April 1st................... d8veh would not need such schematics
Unfortunately I didn't get any photos. My Samsung Galaxy S2 got an automatic upgrade to Android 4.1.2. Since then, it gets red hot and the battery goes flat in half an hour. Sometimes it goes so flat that you can't get it to start again, so I have to swap batteries with my friend's phone. The draw on the battery seems to go higher than what the charger can give to get it going. So if anybody has got a fix for that, please let me know. it's rendered the phone useless. It's something todo with media that's going all the time. I've done a "force stop" and I've disabled it, but it starts up again all by itself.
The phone was working last night, and I was hoping to take photos during dismantling, but never got the chance because everyting fell out and then I started panicing. Now the phone's packed up again. I'll have to go over to Saneagle again when he gets back from his boot-sale pilgrimage so that I can swap batteries again..
Kudoscycles
Official Trade Member
Apr 15, 2011
5,566
5,048
www.kudoscycles.com
Dave,not sure if it's an April fool or otherwise,but if it's genuine there is some useful info on your PM about the TCM motor. By the way,I dreamed up the TCM reference and now it seems to being used by everyone,I have no problem with that.
You had correctly pointed out that the TCM motor used in the Woosh bike is the same as used in the Ibex bike,it would have been obvious to all at Redbridge.
If I can help further please let me know.
KudosDave
jazper53
890
18
Brighton
should be able to disable data switch or switch to 2G
shemozzle999
2,826
686
Perhaps Dave at Kudos could dis-assemble one of his motors and post a series of photographs to show the correct assembly sequence.
16,884
Well, D8veh had me fooled for a while....but the irritable reply was AFTER I found out it was all a joke.
Yes, we've both been stringing you all along. Hee hee!!! As Lynda said, its very unlikely D8veh would need any schematics.....he could probably get an electric bike to go to the moon and back (now there's a thought when you all run out of nice places to ride, its just the lack of actual road that might be a problem).
Hope to see lots of you at Redbridge.
Hatti
shemozzle999
2,826
686
My wasted time searching did throw up this:
Re: New Crank-drive Motor
Postby bandaro » Thu Mar 14, 2013 6:11 am
Product Specifications
Voltage : 36vDesign : BrushlessWattage : 201 - 300w
Parameters
1.Driver Unit
Rated Voltage: 36V
Rated Power: 180~250W
Max Speed: 90r/min
Peak Torque: 60N•m
Noise:≤50dB
Temperature: -25℃~50℃
Weight:≤4.5kg
Water Proof Grade: IP54
Standard: EN15194-2009、ROHS
Range: 40km(with only power and 36V/9Ah lithium battery)
Climbing Angle: 6º
2.Electric Control System
Driver: DC brushless controller
Assistance Meter: LCD/LED
Speed Sensor: One Signal
Assistance Sensor: Inside
Assistance Control Mode: Speed Control, Power Control, Proportional Control
Best I could find, seems like a very simple low power drive, will be interesting to see if there is room on the market for it.
jackhandy
1,820
323
the Cornish Alps
This kind of flippant posting is most reprehensible, d8veh & could stop others posting for help ;):cool:;)
