Haibike amt pro. First impressions? ;)
It all started with me renting electric bike from local energy supply company and I was really impressed by humbre Scott29 with 2012 motor.
So I decided to go big and get some cool bike. Haibike was my choice right away.
It was insanely hard to get any bike with my 52 size but after month of waiting I decided to invest in one of the most expensive from their line, the AMT pro.
I'll skip the part that it was poorly setup, with gear shifts not smooth, same for brakes and forks.
But I can do it myself. It is a cheap 6k euro bike after all ;)
But after couple rides my joy was short lived. Some weird cracking noizes showed up in motor. Every time I've pushed hard on the pedals I felt something in motor gonna break apart.
https://www.youtube.com/watch?v=JeS8fJjKNc0
This is 100% going from the motor not from any other part, believe me.
But today I've got another nasty surprize. My rear fork almost fell apart in a humble city joy ride. I didn't make it to mountains yet with this AMT bike! ;)
So the nut from the rear fork just broke apart like that.
I should update video with noises from motor because it got worse lately.
Can't ride the bike in current state though.
To be continued...
  • Replies 53
  • Views 14.8k
It could be grit down the side of the chain ring. Wash it water, not high pressure the same as from a hot tap. Then give a squirt of GT85 just down the edge and if that does it.
Already working with seller on resolving the issues. Just weird that I had a cheap mtb bike for 7 years, never cleaned or serviced it and it works like a charm even today.
Wow, Just shows the difference between dealers and setting the bike correctly.
Your Haibike needs to be set up properly. Its a shame that you have had problems, because it is a great German build! The components on this model are second to none. I would suggest taking this bike back to the dealer you bought it from to have all the problems resolved.
That's what your dealers there for hey?
As for the rear swingarm bolt.. These are reverse thread. Most users go to tighten it up. It then obviously loosens it (being reverse thread). They then tighten it back up having broken the threadlock seal.
There is nothing broken here, the bolt has just been loosened and therefore it has dropped out. You cannot ride the bike like this. You dealer should have a spare bolt to get you going again quickly.
When the problems are resolved... I hope you enjoy your new eBike!
Regards
Martin
I agree about dealer's responsibility to prepare the product for the run. It is a small store whos name won't tell anything to anybody. They state that received bike directly from haibike already perfectly setup.
Though dealer has nothing to do with motor noises issue that I'm still to resolve :)
I'll keep you guys posted how it goes.
Otherwise had some nice over 60-70km runs with it. (got like 300km so far) Was lucky to grab a spare battery on ebay at very reasonable price as well ;)
Martin, Why do they use a LH thread when it rotates equally in both directions?
I have two Bosch bikes and the OP's sounds dog rough in comparison.
Then a safety related bolt fell out.
It's not the first time we've heard of problems with a Haibike.
I am coming to the conclusion they are not all they are cracked up to be.
^^ I've thought that for a while now. As with so many "must haves", can be a case of Emperor's New Clothes .... well, compared to the mark-ups anyway !
I think you're all being a bit harsh. It's a Bosch motor making the noise, which could have been put in any bike. One bolt fell out for an unknown reason. Anybody could've touched that bolt from the time it left the factory for whatever reason. I don't think that you can draw any conclusions from these faults other than that you can get problems with any bike. Paying a lot of money doesn't avoid that. I guess that the disappointment would be a bit higher after spending all that money, though.
Don't see a single conclusion in this topic, just sharing own experience ;)
It is a great bike and I enjoy it. Seller drove home to me today and changed the bolt. :)
Had a nice ride after that already.
Another small thing that got me a bit frustrated is that I had a flat on a second ride. Was furious how these advanced tubeless gave me a flat already.
I didn't really know I have to fill them with that special rubber liquid :) After filling them that puncture selfrepaired immediately.
But this small fact has really nothing to do with quality of a bike ;)
Will be resolving motor noises in autumn. It can take a month to fix the issue with sending bike to Germany. Might as well find other issues.
Would be seriously annoyed if my local dealer said bike needs to go to Germany , why have a local dealer ?
Warranty is the dealers responsibility or why buy from him .
This is a 6k bike not a £500 cheapie
Obviously not a dealer just a transit point to take the profit
I buy japanese motor bikes , sorry sir it has to go back to Japan for a new motor . Get real for goodness sake. This is why muppets like this dealer who sell these bikes should be shut down .
My wisper bought from a local dealer was fixed within 2 days by them , new motor,
Superb service.
Martin on here is the only person I would buy a haibike off.
Edited by Cakey
Hi Dave,
Well... Hope this makes sense..
The bolt is not actually reverse thread. It is however a normal thread bolt but its threaded from the inside of the swingarm. But Haibike put an Allen head within the bolt on the outside so it is easily accessible with tools. This then becomes reverse thread to the user when working on the bike.
As previously mentioned, if someone who doesn't know what they are doing, goes to check its tight from the outside, they will in fact loosen it. This then breaks the factory threadlock.. As this is a moving bolt it can then work loose pretty quickly.
This never happens if the bolt is not played with. Or if it has been removed, but then re-thread locked prior to assembling back together.
Regards
Martin
Hi Dave,
Regards
Martin
As soon as the guy breaks the threadlock, he'll know which way to turn the Allen key. It's true that if the guy did not replace the threadlock then he's pretty useless.
Hi Dave,
Regards
Martin
Hmmmm!. It doesn't make sense I'm afraid, Martin. No matter which side you insert the bolt from, you'd still undo it counter-clockwise from your direction of access if it's a right hand thread. It's only if the head were on the inside of the frame, but you were on the outside when you have to turn it in the opposite direction; however, everybody knows that.
the sprag bearing can get dammaged, but I think your motor may just need greasing.
http://www.musiccity-doc.org/Technical/StarterSpragClutch/Sprag3.jpg
Yes that is basically it! The head is on the inside, but you can turn it from the outside. The bolt is hollow and had a 6mm allen grip within it.
So just to sum up - The head is actually on the inside of the frame, but the user can access the allen from the outside..
If I get a chance I will picture one of my spare bolts of the frame, it will make perfect sense.
Regards
Martin
OK, I got it now.
Still difficult to work out why such a bolt would be used.
Access from the outside could be achieved with an ordinary bolt.
Perhaps the threaded bit of the swingarm has to be on the outside for some reason.
I'm still not too impressed with a fixing for a pivot that relies on Loctite to stop it falling out.
Some engineers don't like that stuff at all, or would only use it to bolt one non-moving part to another.
  • 1 month later...
After some hardcore testing I can give more feedback and impressions.
In 5 days I made over 8,5km climbs in North dolomites Italy in some serious conditions. I'd say some of the climbs weren't really doable even by experienced bikers with powerful legs :) Though I found some very hard for bosch motor as well.
- 11 gears is really must have, I found myself riding on lowest gear a lot.
Not just it makes climbs easy, you have to stay on higher cadence for motor to give away highest torque.
So this was one of the reasons I went for higher level model to get 11 gears and I don't regret it at all.
- 2 batteries are highly recommended. You can do a nice ride on a single battery especially with fresh legs. Though I was right to get a spare battery and ended up taking it with me a lot.
Bosch 2014 battery shape is very nice and it fits in a backpack with a 2L bottle of water perfectly. Weighs just 2,5kg but extendes your drive and relieves tension of getting stuck with empty battery. Also it is nice to swap battery on a 10-15% charge to keep battery healthier. Full discharge kills it faster in a long run.
From my observation single 400watt battery can do 1000-1500m climb no problem depending on legs condition and climb steepness.
I did 2,5 km elevation with 65km distance first day on 2 batteries leaving 15% charge.
- walking assist is insanely nice feature for bosch 2014. I had lots of parts where I had to push my bike up unridable areas and 24kg bike with 8kg backpack doesn't make it easy job. So that small assist button really helped.
Though it is rather weak assist and you have to put bike on highest gear for best pushing power. So overall procedure looks like this. You get stuck on lowest gear, stand and switch bike to higest gear, rise rear wheel and push assist buton for bike to switch to highest gear.
Placement of that button isn't handy as well, considering you have to push that heavy bike on rough stony areas and hold that tiny button on flimsy plastic console.
Had just two small accidents.
1) chain got stuck on that small front cog on a motor. Lower part of chain was catching up on a cog and jamming it up.
I think it was just dirt and stones, cleaning the chain helped.
2) Another glitch I found was motor stopping assistance after some idling time. When you stop pedaling for a bit and resume, the power just not there. No matter how you change assist setting there is no power untill you power down the whole system and power it up again.
Also had an error code once, that could have been caused by overheated motor I suspect. Resting a bit and powering the system down and up helped to solve that.
Some design flaws.
Rear shock is completely open to dirt and flying stones from rear wheel. I've closed it with a sick duct tape which works perfect and keeps it clean.
A small plastic chain guide on a small cog above the motor doesn't only help. If you ride into a bit of dirt it gets stuck on that plastic guide stripping the chain of all lube in minutes.
Here are some photos from my trip.
DSC01865.JPG.de19c7bf61ee35fdbe9998f055a59ae2.JPG DSC01947.JPG.4594859cfb950f334b4e360d60217003.JPG DSC02009.JPG.0b5735eb0de9e182473b9bab301b8ec7.JPG DSC01903.JPG.9610f1a7167810b95e3796ab6230f022.JPG
  • 1 month later...
Ok I'm happy that bike didn't fall apart yet though I get more new exotic noises. Most awful is kronolog making annoying creaking noises. I really love it's functionality though I'm afraid might be forced to throw it away some day ;)
Another scary thing I've noticed when pedaling heavily uphill on very steep slopes that rear wheel is making sharp creaky metals sounds. You can hear it on the video.
Not very happy with rear wheel bouncing to sides like that. My old cheap cross country bike with cheap wheels looks more solid ;)
https://www.youtube.com/watch?v=SIovLZa8bGg
Do not ride this bike with the rear wheel having that much play in it!..
Make sure it is the rear wheel and not the pivot bolts that hold this play, only reason I mention as I know previously that you didn't have them done up correctly and lost a bolt.
This needs to be taken to a dealer and adjusted correctly before you next ride it.
