Guest Bike Conversion
Benjahmin
2,661
1,781
70
West Wales
I've had an answer from Jimmy, I'll put it up here because what he says may interest others:
Hi Ben,
Thank you for your email regarding your battery requirement. You have chosen a good time to contact me as I have just acquired the best battery welder in the universe. The welder is the 250i2 EV from Sunstone Engineering and is a pulse arc welder that can weld copper interconnects. Usually nickel is the chosen interconnect material which is 4 times less conductive than copper.
Copper is only second best conductor of electrical current to silver (100%copper, 105%silver, 22%nickel), the due to being a difficult metal to weld, nickel is most common. The ultimate battery would be one that has copper interconnects which would have the best power, lowest overall resistance (creates heat), longest life cycle, just to mention a few of its benefits.
The choice would be either Panasonic NCR18650B 3350mAh, or NCR18650PF 2900mAh. Using the B cells the capacity would be 17Ah or 14.5Ah with the PF cells (5P10S configuration). Cycle life is 500.
I would strongly recommend the Boston Power Swing cells (USA) which would be over 15Ah with a cycle life of 2000-3000. These are excellent cells that NASA use in their robots as well as Volvo in the ev.
I normally use 25A continuous current discharge high quality BMS with my builds which means cooler running and higher reliability. The price of the build would be £325-£350 depending on which cells you choose. Needless to say, I'd be using copper interconnects for obvious reasons.
Best regards,
Jimmy
Anyone heard of the 'Boston Power Swing cells'? Sounds like some sort of 60's elite wife swapping group:eek:;)
Reactions: anotherkiwi
Benjahmin
2,661
1,781
70
West Wales
Thanks Trex,
I was thinking of asking him for a 4P10S made from Panasonic B cells as this would work out at 13.4Ah, which I think would do.
As for the copper straps, what he says about conductivity makes sense. Is the concern for a bi-metal junction at the battery?
trex
7,703
2,671
yes, that's what bothers me about copper tabs. The choice is down to the metal used to make the cell cans. Most 18650 cans are made of stainless steel coated with nickel, so we know nickel tabs work well.
8,750
eBike Battery Team
Official Trade Member
Nov 27, 2015
24
40
London
ebikebatteries.co.uk
Hi Ben,
Best regards,
Jimmy
Re the Boston Power Swing cells, here's a link which you may find helpful: http://www.boston-power.com/products :)
Reactions: KirstinS
Benjahmin
2,661
1,781
70
West Wales
Bike bits ordered, all from Rose.
Front Magura HS11. An Ergotec 300mm quill stem and the Shimano 21 speed shifters.
I'll be ordering the kit when the debit cards cooled down a bit.
Yet to make a final decision on the battery.
Benjahmin
2,661
1,781
70
West Wales
Just tried to order the wheel, controller etc, from BMS. It came to £124.35 BUT it said shipping would be £100.87 !:eek:
Is that usual?
Sounds about right. Where else can you get that stuff from for £225?
Benjahmin
2,661
1,781
70
West Wales
Well I had started to look at the Panda bikes front wheel kit for £250, at least it's only being delivered from Nottingham. But is it any good?
The Panda kit is very good. You get a guarantee too (sort of). I prefer the Q100H motor, but there's not a lot in it.
Benjahmin
2,661
1,781
70
West Wales
Thanks d8veh.
The Panda motor says it's 187rpm for a 700c wheel, whereas the BMS one would be 260rpm. I guess this would mean more torque, lower speed from the Panda?
Also I'm putting a Magura HS11 on the front, the Panda spec says that the kit is unsuitable for hydraulic brakes. I'm guessing that this is just because of the supplied cut off levers, not that the twin wall rim isn't suitable.
I'm veering towards the 'Eco' kit for £220. As far as I can see the only difference is a LED display instead of an LCD. For a guest bike I think that would do. I guess that would loose the de-restrict function, oh well.
Yup, you've figured it all out pretty well except that you don't need to worry about derestriction with a 187 rpm motor. You don't necessarily get much more torque, but you get better efficiency at low speed, which means that you can climb steep hills for longer before the motor heats up and you use less battery. the torque depends on whether they change the speed by the motor winding or the internal gearing - most likely the motor winding, which doesn't give more torque.
Benjahmin
2,661
1,781
70
West Wales
Magura brake, gear changers and quill stem arrived from Rose today. Just ordered eco kit from Panda. The bullet has been bit and the fun begins.
