Have a look at the main fuse on the battery to see if it's blown.
Did the panel get visibly damaged in the fall?
Although this panel looks different, I've got a feeling that it works the same. If you can, follow the wire all the way to the controller to see its connector, it might be interchangeable if there's four wires.
Electric bicycle intelligent LED display, CE and ROHS approved King Meter 790-in Electric Bicycle Motor from Sports & Entertainment on Aliexpress.com
Do not try to straighten your brake lever cold. It'll break before it moves much because it will have work-hardened at the bend. You have to heat it to nearly red hot,let it cool down and you'll find that it bends easily for a bit and then stops. You then have to repeat that process until it's back to where it should be.
