Double pinion kit for bosch emtb
Gubbins
The problem was the rubber oring that sits on the flange. The inner ring isn't affected but the outer one has a built in spacer which sits over this rubber ring . Take it off and it's fine. What does it do exactly?
6,733
i thought that rubber ring went on b4 the lock ring not got it on my bike and have the bearing seal.
if its working just leave it off will not do much tbh ;)
6,733
you still cant add that spanner to the basket lol, i want 1 now but just want the sprockets without the lock ring/bash ring and not an option.
will have to save my penny's ;)
Gubbins
Told me they don't sell it on its own due to high cost of management.. lost in the translation..
It seems to work OK.. I wanted to be able to go slower on tricky uphill bits and now I can
Reactions: soundwave
6,733
i bought mine on its own lol ;)
6,733
mine has never come loose. tho could put a dab of lock tight blue on it :)
6,733
my back wheel is not bent in half tho pmsl ;)
6,733
3.28
spokes all still tight so think that thing is dead.
27.48
rear mec cage snaps in half.
Reactions: EddiePJ
6,733
get some 2 part rotors helps get rid of heat build up and more stopping power 203mm front and back on mine.
6,733
does the 18t sprocket look like this ?
that is in 1 piece or do you have a separate spacer as that one was custom made and not for sale.
he also has 13t for the smaller sprocket and cant find them anywhere.?
6,733
i think if some one could make a spacer that size then could just use two normal sprockets and be a lot cheaper.
cmon eddie sort it out ;)
6,733
id want 16t and 20t for my bike but its not an option unless i can find a spacer to work with the normal connex sprockets.
tho as eddie wears out the smaller sprocket will be cheap to replace and give him the speed down hill and not spin out with the 18t.;)
Related Articles
