The distances you are getting sound quite good but they do depend on how much effort you put into peddling and how much you use motor assistance. Would you please explain a little how much effort you are putting in. Do you use the throttle, if so how much, ...Do You have motor assistance throughout the entire ride or just occasionally?
I'm not a strong cyclist (under 70Kg), but I like to be constantly "pushing", with downward and upward pedal strokes. I get bored if I don't feel the human effort (i.e puffing + sweating
Baring in mind that the assistance is available up to about 24km/h, and that I do 20km/h average, 40-50km/h max downhill:
I normally let the Pedal Assist Sensor control the motor power output, which means that I must maintain a high cadence to get rewarded with this "bionic leg" sensation. I'd say that the assist is on most of the time, albeit at low levels (I notice the difference when the assist if off, I can feel the extra weight and drag of the e-Brompton!). I don't keep my eyes on the Cycle Analyst display, but I think between 40W and 200W is provided most of the time up to the legal speed limit (which I believe is a technical limit in my case, not a setting I can override). Anything between 200W-400W is what I would call "serious" assistance, only occurring when climbing. I must double-check these figures though.
Sometimes I have less stamina, so I prefer to crank-up the throttle and use a low pedal cadence / high torque. I will sometimes stand on the pedals to climb serious hills, but to be honest most of the time high-cadence works fine at 400W/12A peak. The Bafang is a great climber, no doubts about that, but not when used like a moped !
I mostly use the throttle to take-off from a standstill (whilst pedaling of course), it is a really helpful feature, especially in traffic.
I have just purchased Power Grips to transfer leg power more efficiently into the pedals, this should help me keep the battery consumption down. See here:
http://www.pedelecs.co.uk/forum/electric-bicycles/5132-its-cold-dark-windy-raining-never-mind-2.html#post65651
or do you use the three position switch, if using the switch, what setting do you use most of the time, position 1, 2, 3?
1: when I have to be "careful" (when I "walk the bike", very slow traffic, pedestrians wandering around, etc.).
2: slow-moving traffic, starting from standstill (with throttle help).
3: most of the time.
I am interested because I have the same setup as you but with a 15 amp hour battery and was wondering what sort of range I could expect to get.
15Ah LiFePo4 from Li Ping ?
Bafang 255rpm ? (the gearing probably affects the statistics, depending on the terrain)
Cheers, Dan
