Start with the trailing spokes on one side of the hub, running on the inner side of the flange. Between each spoke, skip one hole on the hub, 3 holes on the rim. Repeat the operation on the other side of the hub. Then lace the leading spokes running on the outer side of the hub flange, leaving one free hole on the rim each time, so that the last pass on the other side of the wheel fills all the remaining holes.I am looking at that front wheel lacing pattern ready for when I start mine![]()
Thanks Dan. I've been reading up (Sheldon's web site and I purchased that online book on wheel building by Roger Musson) about lining up the hub writing and rim text all viewed through the valve hole. Although not essential its good practice apparantly.Start with the trailing spokes on one side of the hub, running on the inner side of the flange.
Oops, typo ! Thank you.As I see it isn't this a cross-1 lacing i.e. spokes only cross one other spoke ?
Wheel BuildingBy the way, whatever the cross pattern is, only the outermost spoke crossing is "interlaced" (spokes go behind one another). I've always wondered what it meant for cross-1, as there's only one crossing![]()
I think we shouldn't interlace them, because our particular application (cross-1 with small diameter rim and large diameter hub) means that the trailing / leading spoke pairs would be very hard to interlace without bending them considerably.
1-cross has similar properties to radial (lower angle of incidence).PS I had thought that you ALWAYS lube nipples and rims EXCEPT for radial builds ?
NopeSo did you use a thread locker compound on yours
I'm not sure what you mean JerryIn this 1-cross pattern I assume you don't have to rotate the hub during the build ?
