Diamond Frame Agattu - The Photo
simonbarnett
338
25
West Hampstead, NW London
Hi Tom- got back from abroad this evening and Tim was on my doorstep 30 minutes later with my Kalkhoff- looks great so hoping weather holds up for a maiden voyage tomorrow. Glad yours is good - it's been a long wait.
musicbooks
719
29
I name this vessel.."The Long-Awaited" Happy sailing!:)
BW
musicbooks
StrangeFish
59
Bristol (BS14) UK.
As promised..Enjoy
BW
musicbooks:)
Hi musicbooks! Forgot to thank you for putting the photo up earlier. Your frame size and style is the same as mine which is waiting for me to collect at 50c. However, I am unable to collect until next Sat.(12th). So I console myself by regularly clicking on the photo of your bike and having a look before scanning the posts on the forum. We have had a couple of pleasant days weatherwise, so I expect you have a few more miles on the Agattu by now, am I correct?
Regards,
StrangeFish :)
musicbooks
719
29
Regards,
StrangeFish :)
Hi Strangefish,
See my recent entry in Agattu- first impressions thread.
BW
musicbooks
musicbooks
719
29
How was your maiden voyage Simon?:) :)
BW
musicbooks
simonbarnett
338
25
Hi Tom- bit restricted, I'm afraid. By my 10year old daughter insisting on joining me on Saturday and by snow today. But I managed a short 3 miles each day and it's pretty impressive.
Minor gripes are 2 cut cable sleeves on front brake and gear cables and nowhere to mount a secondary rear light. Oh and Tim forgot my free panniers!
I want to test a bit more (but won't commute on it until weather improves) especially up hills, but I'm pretty sure it is undergeared- I had no use for gears below 4th.
General question for others- on the dull sprocket change question, is there a set number of links to remove on the chain for a new 19, 18 or 17 tooth sprocket?
30,745
One link for every two teeth smaller Simon. One either side of that to cope with odd numbers is not a problem, the frame dropouts and the Panasonic's idler sprocket take care of variations.
Mandy
512
Thanks- not sure what a frame drop-out is, but I get the drift!
There is a vertical and horizontal drop out to fix the frame to the wheel.
The horizontal will allow wheel adjustments with the chain as moves from side to side or backwards and forwards, however the vertical being upright will not as it is less forgiving and it is fixed with very little or no play regarding chain adjustment as moves up and down and would not help with adjusting the chain length due to the wheel being fixed.
The Agattu must have the horizontal one :)
Regards
Mandy
30,745
It's the slot the wheel bolts into Simon. One tooth will shift the wheel spindle by a quarter inch, so if you have an odd tooth to adjust for, do it this way:
If the wheel is near the back of the slot with not much more movement possible, take out the extra link from the chain. If the wheel is well forward and near the dropping out point, don't take out the extra link, just remove one link for each pair of teeth, ignoring any odd tooth.
Tim
770
78
London
Someone is taking a wholly unjustified pop at the Kalkhoff on the Sunday Times test bench page. Funny how they recommend another shop isn't it...
Test Bench: Electric bikes - Times Online
There have been absolutely no battery issues with the Kalkhoff, in case you're wondering! :rolleyes:
S
stokepa31
I saw that Tim. I doubt they ever tested it. Makes you wonder who they really are.
simonbarnett
338
25
Thanks Flecc and Mandy- of course I realised what it must be just after I'd posted:eek:
Joe
107
well harry seemed happy enough hey tim!
and you got through your last livs.
up on the whole deal i would say :)
essexman
212
cb11
Hi Just some feedback on gearing.
I had planned to mod mine, but actually i dont think i will. I live in area with a lot of steep hills\slopes and i plan to move a lot of weight and\or avoid sweating up them, so i think i'll keep my gears as is for the minute.
I'll see how i feel after a hot summer (fingers crossed).
I'm a skinny spinner, so i dont like heavy gearing generally.
Mandy
512
Hi Essexman
You haven't explained your grearing problems that I can see?
Please elaborate and one of the Guru's will get back to you, namely Flecc hopefully?
Kindest Regards
Mandy
essexman
212
cb11
Hi mandy,
It wasnt a problem, just an observation. SimonBarnett is changing his rear sprocket like many people are doing or planning to i think, beacuse he feels the gearing is too light.
I was observing that i found the gearing a little light when theres just me, but as i add weight it becomes barely adequate. I think this is becuase my cycling style is fast and light, rather than strong and slow.
Cheers for the offer of help though.
