Dahon Jetstream conversion
cwah
3,048
179
www.whatonlondon.co.uk
Yes looks much cleaner.
I did the battery myself with us18650V3 cells. I've choosed them in the past because they were cheap and have good life cycle. I may buy ncr18650b if I can.
The pack is a 9×14s = 126 cells and 1000 wh.
Which is a decent contender from my other pack. :)
cwah
3,048
179
The tape wrapping the battery to the aluminium board teared down. I tried heavy duty tape but it still can't handle vibration from bike and also split apart.
I need some sort of heavy duty Velcro or belt to keep the battery on the aluminium board. Something that keep it on the bike but where I could have a quick release to take the battery out.
Any idea of a strong heavy duty with quick release strap/belt?
8,736
Quite a bit of weight to keep in one place without wanting to shift !!!
I liked d8veh's solution for rear battery holder which I saw at Redbridge.
A ply base board that fits in the bottom of a sports boot zip bag this is then bolted through to the carrier, any sloppieness of the battery can be padded with foam.
jhruk
318
68
I'd have thought you'd need something, such as velcro, to stop the battery sliding on the base and then a strap to hold it down securely.
I use a rack pack with Velcro attachment and put a cam bucle strap around it. It's held a 5kg battery secure for several years. The straps are easy to tighten and quick to release.
Cam Buckle Strap
derf
1,007
766
54
Update on my conversion:
- I have dual big apples. It looks like it does take longer to worn out. But I only have them since 3 weeks. Time will tell.
- All sine wave controller I tried to date are damn bad. They are noisy over 75V, do not regen and/or are less efficient. I'm using back square wave controller.
Rear seat is finally installed (D8veh licensing!):
As you can see, I used 2 aluminium tube because I'm planning to convert it to rear seat. I'm going to have a test subject very soon.
Same for the rear trolley, I'm using this silverline one:
http://www.amazon.co.uk/gp/product/B000LFYO7E/ref=oh_aui_detailpage_o04_s02?ie=UTF8&psc=1
For now, all seem good. I did a 30 mn run with strong start, max speed at 30mph, potholes, start&stops... It holds it well.
Next stage, get a test subject and put some luggages on it. I hope it's going to hold it. And it's 3 years warranties anyway :D
farting nora that's brave, I'd have loved to see the test run with the unsuspecting trolly finding itself doing 30 mph on a potholed street...thanks for the detailed write up, it helps loads with my work in progress
cwah
3,048
179
Thanks guys, I have my 2 straps now, it's working nicely!
I can even put my work bag on top:
I can fold my bike in my room:
Now I need a tool to remove my single speed to put a multi-speed:
Any idea where to get a good cheap one? thanks
cwah
3,048
179
My rear rack is wobbling!!
Do you have any idea how I can fix that? I fear it may falls on the floor someday!
All your clamps and struts are loose. You need to fix them tight.
cwah
3,048
179
the aluminium rods start to break apart...
maybe i should get stainless steel? or did i install them incorrectly?
With the weight of your battery, normal steel tube would be best.
cwah
3,048
179
My handlebar is down :( :( :(
I tried to put a allen key to open the screw on the bottom but it doesn't work
Not sure if the bolt can be removed actually... do I need some sort of giant allen key on the top?
cwah
3,048
179
Removed it finally:
What should I do next? Any good and cheap fork to buy?
cwah
3,048
179
Twangman
114
19
London
I had a ridgeback folder which is the same bike as your Dahon just rebaged. I had a similar problem with the handlebar fold mechanism snapping. It's a common problem. It's a design flaw as far as I could see, I had a friend weld it but it only lasted a few weeks.
cwah
3,048
179
I tried to remove the fork and the bearing from the bottom fall off :(
I've lost a lot of little bearings ball:
where can i find cheap replacement???
