Just in case, you should check that the phase wires aren't damaged fron the wheel twisting. That can make noises like that too.
Its all a phase that the most of us go through, I know because ive been there. Soon you would want that thrill to meet you half way as in half the thrill and the other half in more comfort, reliability, endurance, efficiency and practicality . But in the mean time by all means enjoy yourself to the highestI'll probably stick with 20" wheel even with bigger bike. Because I thrill acceleration![]()
U got most of them rightI received my Sine wave controller and the instruction. Unfortunately I do not read chinese.
Anyone can help me?
My understanding from left to right:
1. ??
2-3-4: Phase sensor
5: Main positive
6: ?
7: Main negative
8: ?? Maybe speed control? There is 3V coming through on both of the wires
9: Hall sensors
10: Reverse
11: Reverse when connected
13: Throttle
14: Ignition
15: ?? Maybe high power brake? How do I use that?
I contacted the shop, they didn't answer me. So I decided to buy it cheap from Amazon:Assuming your Jetstream has a 20 spoke QR front wheel I think this one is a direct replacement:
Kinetix 74mm Front Hub
They have a cheaper nutted one here:
Dahon 20 hole Nutted front hub
Complete wheels from £24.99 : Dahon wheels
If it's just the bearings gone you should be able to replace them. The Kinetix hub has cartridge bearings so you'd have to knock them out & measure them, I don't know the size.
Yes that what I've done, I've seen some wire at 80V (my battery voltage). Don't know what these are for. But yeah I'll be careful.When you're using an unknown controller, you should connect the battery wires, then check every other wire with a meter. Some will have battery voltage and some will have 5v. You can't do ant damage with 5v, but if you connect a battery voltage one to anything, you can kill your controller, throttle or anything else.
The front hub is repairable. It's probably just the bearings that beed adjusting or replacing. You need to dismantle it to see what state it's in. You should be able to get the bits in a cycle shop.
You need to measure the voltage between the throttle black and signal wires while it's running to find out what's happening at the point it cuts off. Does the throttle signal disappear or does the controller only allow a maximum voltage?
Check that the voltage on the high-voltage throttle wire is zero, then when you connect it to any 5v wire with a switch, it'll cut the motor. A hidden wire brake sensor might work if you put it backwards so that the LED is on all the time, and goes off when you pull the brake, but I'm not sure .
