A pic of any cell writing might be useful but if they are China cells they might not even be 10a capable ?
That's all I can see on the cells.A pic of any cell writing might be useful but if they are China cells they might not even be 10a capable ?
That's what I thought tbh i don't understand why I'm only getting 52.2v when all cells add up to.more individually.IMHO, those cell voltages are quite acceptable and not anything to worry about. Yes, it is a little out of balance, but I'd expect that on a battery with unbranded cells, where you're taking 5.6 amps per cell. Also, there’s somthing wrong with your measuring. Those cell voltages add up to around 58v, but you were measuring as low as 52v on the output, and every time you measured the output voltage, you seemed to get a different value.
Before deciding anything, you should put a new battery in your meter and measure everything again carefully - cell voltage and voltage on the battery terminals.
Let's assume that your measurements were correct and your cell voltages add up to 58v, but you terminal voltage is only 52v. The reason for that would be what's causing your problem.
Oops I just finished charging the first one to 4.16 at 1ah, I'll turn it down to 0.5 for the rest.To be safe you can only charge the low cell group singularly with a max 5v charger with a low 300- 500ma charge to be safe and then you have to very carefully monitor the live voltage rise for each cell group.
Your meter has a battery in it - normally a PP9 9v. That's what you should change, then do all your measurements again, not measure another battery.I don't have another battery to test unfortunately.
Oh sorry I misunderstood. I just try with a second multimeter and the readings are the same.Your meter has a battery in it - normally a PP9 9v. That's what you should change, then do all your measurements again, not measure another battery.
First you have to determine the facts by measurement, then we can think about the cause.
They are 2600mah China cells, that's to that can be said, 9 x 2600 gives you the 23.4ah capacity.That's all I can see on the cells.
What’s the total voltage from the cells and what's the voltage on the output teminals? What's the same? The output voltage can't because you gave 3 or 4 different values before.Oh sorry I misunderstood. I just try with a second multimeter and the readings are the same.
Hi sorry for late reply I have been away. I charged everything individually like you said then connected BMS back on and charged for a few hours and new readings are now :They are 2600mah China cells, that's to that can be said, 9 x 2600 gives you the 23.4ah capacity.
Hi sorry for late reply I have been away.What’s the total voltage from the cells and what's the voltage on the output teminals? What's the same? The output voltage can't because you gave 3 or 4 different values before.
Voltage reading should about 57.98v so something is a miss with a reading of 52.5v.
If you take a voltage reading directly of the battery one should see an appropriate reading of 57.9v or so, if so the BMS must be faulty not to give a full reading on the discharge side.
Thanks so much guys it must be a faulty BMS. I'm getting 58.3 volts when bypassing the BMS. I'll order a new one and I appreciate all the help from you all.You're missing 5.5v!
You need to find out where it is. Measure the cell-pack voltage directly between where the thick red and thick black wires are attached, then from where the thick black attaches to the cell-pack to the positive output terminal, then keeping your red probe on the positive output terminal, move your black probe to where the thick black wire from the cell pack attaches to the BMS, then where it leaves the bms, then the output terminal. One of those five measurements will tell you where the voltgae has gone.
Don't buy anything until you find where the voltage drops. Do the tests I said.Thanks so much guys it must be a faulty BMS. I'm getting 58.3 volts when bypassing the BMS. I'll order a new one and I appreciate all the help from you all.
Oops I already removed the BMSDon't buy anything until you find where the voltage drops. Do the tests I said.
Read my post above again. I added to it.Oops I already removed the BMS
I see, do I need to solder BMS back on to carry out the tests? I had trouble following your instructions sorry.Read my post above again. I added to it.
