Computers and stuff...
17,124
did you buy that laptop at the end?
6,688
prob get it weekend if not been nuked :p
6,688
6,688
6,688
6,688
looks like i need another ap as got 23 devices on this one and if the bit rate of one of the cams drops below 140 it keeps cutting off :confused:
i need more power :D
6,688
:p
6,688
6,688
fkn thing nearly cost as much as the fkn 85inc tv :eek:
6,688
wifi 6 it come complete with a celling mount kit for a office tile and the plastic part it clips to is missing ffs :rolleyes:
6,688
:p
17,124
What is it in the first picture? Your Wifi6 router?
6,688
6,688
6,688
i have been using this stuff since they made there first access point that you use a pc to run the controller gateway on now its a cloud key or a dream machine is it all in one unit that you log in to via 192.168.0.7 ect
the g3 cam on the back the ap has to go through 2 solid concreate walls it kicks the virgin routers ass wifi wise as never used it.
even linus tech tips uses this at work and at home but it gets a bit limited if you want a 10gb switch but they did just release a nas
no hdd of course but will need to use a raid setup so 2 drives for redundancy if 1 fails.
and the best bit is i not got a clue about networking i just plug it in it does its thing gets adopted and just works out the box.
and you can remove remote access so only local log in or you need a ui account https://account.ui.com/
17,124
For cheap raid, I have a second hand hp DL380 with 10 x 2.5" sas drives. You can set the raid array to raid 5 or raid 10, dead easy on the DL380, just tick boxes with the mouse. I paid £125 on ebay for the lot. For wifi, I use a bunch of 1.3gb dual 5G sticks. They cost me £5 each. For remote access, I use tailscale. It's free. I run mostly dockers nowadays.
6,688
17,124
Those are bl**dy expensive. I use a bunch of tapo cams. They cost peanuts. They record onto microSD but you can simultaneously record using their cloud storage or you pc using onvif protocol.
