Computers and stuff...
6,693
gta6 different ball game as games dont tend to use multi core cpus or not many threads of one so the more cores you have the slower the cpu and naff frame rates.
plus you need a power station to run it :eek:
3,346
I like his monitor setup, I could do that, have the same size screens. Megadesk TF, doesn't look too hard to knock up.
6,693
:p
3,346
Need a replacement LED. Will measure voltage with needle probes. Can't find the plastic slider with LED anywhere, will just be the LED...
55739
55740
17,159
I watched a yt video how a guy repairs 7 M1 and M2 apple laptops.
5 of them died because of a single passive component, a tantalum cap, 1 died because of an IC in the slave power management, the last one died because of the M1 cpu malfunction. None has any thing to do with use. Apple doesn't sell their custom made chips to repairers.
Who would want to be one of their customers if they knew?
6,693
they will sell you a hole new logic board tho 95% of the cost to just bin it and buy a new one :p
3,346
Won't be long before they accept crypto, and sellers trade from virtual offices owned by companies registered in the Caymans rented through Liechtenstein controlled via Tuvalu.
3,346
and it farts :p
...and this is perfect for deep and in tune loud atmospheric classical farting, when a separate amp is driving the subs of Mission floorstanders only, with no mids and tweeters being driven by the second amp - relaxing and non-distracting noise to code to.
55756
6,693
3,346
Is that all in G? All tension and no relaxation, or the only relaxation being different tension. Key is the synths - my mate makes noises like that, for hard techno, dark, 136 to 160BPM. Sounds a bit cleaner, but not by all that much. Do many fights break out at those gigs? I bet there's greater violence in more vanilla clubs, like those regular machette battles at the Hacienda. No chicks = fewer fights regardless of the music genre... or are those gigs full of seriously rough twisted chicks? Hoops through their achilles and the backs of their skulls and all that? Not judging BTW.
I might have a go at making something like that, when I get a bit of free time to fiddle...
6,693
cant get usb hdd to work as has no drive letter yet kbd and mouse work fine and can link phone via usb and it sees them.
thumb drive dont work but there in disk part same as hdd yet no drive letter cant formatt them either and work fine on other pc.
usb microscope shows up as unknown device in manager and also does not work it is all set as it should be and makes no bloody sense at all :rolleyes:
got a new usb pcie card 2nd one and same problem also nothing on usb 2 on board slots either wtf
3,346
Can you play GTA Whateverversionitisnow?
6,693
i can download it from steam but i did try ausb dvd drive and it does show up, and the tablet is also working so it does not make any sense at all.
i can also format the drives but there is no drive letter and if i try and change it just comes up with that error msg.
also changed the drive letter in other pc it does not show up as blank same as in pic
17,159
6,693
it is not there :rolleyes:
17,159
Did you disable and re enable the USB drive in device manager > drives? I can't see properly your pc screen on my phone
6,693
i have tried it all and cant get it to work yet other things work fine the drives are there just no drive letter all drivers working in device manager 2 usb 3 cards and still the same thing.
yet the drives work fine in other pc i tried to change drive letter to f and still cant see it on this pc as no drive letter.
it will let me formatt it but again no drive letter wtf
