Charging pack to 41V experiment
jimriley
619
413
All very interesting. So might there be a fairly safe regime using a programmable charger to limit the cut off to whatever voles, with an ordinary battery. There was a comment that BMS only needed after 100 charges. So play safe and do BMS one in 20 or something. It would extend the life by some amount.
WheezyRider
1,690
938
It seems to be the case that if you have a good quality pack, you could get away with a balance charge once every 100 cycles. To be safe it's probably best to do a balance charge once a month.
Some BMS units have a Bluetooth connected app which allows you to look at all the individual bank voltages without opening up the pack. Definitely worth considering if you are building your own pack.
WheezyRider
1,690
938
I've been doing some experiments too. I found out that if you keep the cells at the 3.7v they arrive at, they last forever.
Depends whether you could get any useful output from your experiment.
The point is it's about the compromise between useful capacity and battery life. 40.5V max charging may be a bit low in terms of useful capacity. 41V seems to give both a decent capacity and a reasonable life. The amount of capacity between 42V and 41V is negligible, yet charging to 42V seems to have a significant effect in reducing the life of the battery.
Reactions: Nealh
3,994
The whole idea is fraught with risks and full of ifs and buts and probability, plus it's a load of hassle to organise and monitor.
As I said before, unless you're a very high mileage rider, just charging normally, your battery will last for years, by which time there will be better ones. Batteries have been improving by about 10% per year, so in 3 or 4 years time, you'll be at a 30% to 40% disadvantage compared with a new one. When I built my bike 6 years ago, I had 11.6Ah. Now I have 17.5Ah for more or less the same weight.
WheezyRider
1,690
938
Yes, I agree, at the moment, for most people, it's not worth the hassle.
However, if you are technically minded, have a pack which costs more than the motor and controller combined, if you can, doesn't it make sense to try and extend it's life where possible?
We live in a throwaway society and it can't carry on forever.
The world is full already of electronic waste. The extraction of the lithium is energy and water intensive and causes environmental and social issues in its extraction. There are also lots of unpleasant/strategic chemicals in lithium cells that have to be manufactured, creating further issues with waste products and then ultimate disposal. Most lithium cells are still not recycled.
Furthermore, from these kind of experiments, it becomes likely that more intelligent chargers will be manufactured to prolong the life of battery packs by charging to <42V most of the time and then occasionally doing a balance charge. For instance, if you had a Bluetooth BMS, it could transmit to the charger whether a balance charge was needed or not. Then it would all be automatic and hassle free.
Reactions: Jerry Atric
8,841
The simple answer would be for all future generic BMS to be programmed so they balance at 4.1v per cell group to extend the life of the cells/battery. The throw away world can't go on for ever with resources being used up.
My 29E's batteries both 6 years old and only 3 or 4 digits difference between serial numbers behave the same at 41v max charge. No deterioration in mileage use or an shenanigan's in use, I simply adjust/set the San's voltage pot to the voltage required and they charge up nicely. All I do is check the battery charge voltage when the green light appears and monitor mileage usage, the longer I eke them out for my local usage then the more user friendly they are for the planet. In the bigger pics of things not going to make much difference but I'm doing my little bit for the world.
Reactions: WheezyRider
WheezyRider
1,690
938
Latest update:
Battery pack is now up to 40 cycles of 4.1V charging and discharging to approx 3.68V per cell.
All banks are still within 0.01V when charged and at most 0.005V when discharged.
Reactions: Bikes4two
WheezyRider
1,690
938
Should hit 60 cycles tomorrow, at 59 at the moment.
After 56 cycles I measured the pack on a Fluke bench top multimeter, with 4 decimal places, as ordinary cheap multimeters are not that accurate and I wanted to be sure I was getting reliable data.
Discharged to 37.079V:
Bank no. ) Voltage
1) 3.7097
2) 3.7090
3) 3.7092
4) 3.7076
5) 3.7075
6) 3.7110
7) 3.7114
8) 3.7100
9) 3.7107
10) 3.7080
Biggest variation 3.9mV
Charged to 41.034V:
Bank no. ) Voltage
1) 4.1025
2) 4.1004
3) 4.0990
4) 4.0999
5) 4.1003
6) 4.1114
7) 4.1042
8) 4.1056
9) 4.1029
10) 4.1088
Biggest variation 12.4 mV
WheezyRider
1,690
938
As promised, went through 60 cycles today.
Put the pack on the Fluke bench top multimeter again and had another look:
Discharged to 37.363V:
Bank no. ) Voltage
1) 3.7356
2) 3.7356
3) 3.7351
4) 3.7345
5) 3.7341
6) 3.7398
7) 3.7380
8) 3.7389
9) 3.7383
10) 3.7375
Biggest variation 5.7mV
Charged to 40.913V:
Bank no. ) Voltage
1) 4.0901
2) 4.0883
3) 4.0870
4) 4.0880
5) 4.0882
6) 4.0992
7) 4.0919
8) 4.0936
9) 4.0909
10) 4.0966
Biggest variation 12.2 mV
So still no significant difference.
For comparison, I had a look back through my logbook and I found I did actually put the pack on the Fluke back in August, after only 9 cycles of 41V charging:
Charged to 40.984V:
Bank no. ) Voltage
1) 4.0981
2) 4.0949
3) 4.0940
4) 4.0937
5) 4.0955
6) 4.1067
7) 4.0989
8) 4.0996
9) 4.0997
10) 4.1031
Biggest variation 13 mV
So no significant difference from 9 to 60 cycles.
Reactions: Bikes4two and Nealh
8,841
Good work WR, I don't bother recording with my 29e's as I have no extra sense wires on the exterior to measure off. Though am not seeing any major reduction in voltage sag or range so cell groups are appearing to to be maintaining good relative balance.
WheezyRider
1,690
938
Passed 71 cycles today.
Discharged to 36.963V:
Bank no. ) Voltage
1) 3.6963
2) 3.6956
3) 3.6957
4) 3.6945
5) 3.6946
6) 3.6983
7) 3.6981
8) 3.6980
9) 3.6978
10) 3.6959
Biggest variation 3.8 mV
Charged to 41.041V:
Bank no. ) Voltage
1) 4.1029
2) 4.1008
3) 4.0995
4) 4.1006
5) 4.1009
6) 4.1121
7) 4.1048
8) 4.1063
9) 4.1034
10) 4.1094
Biggest variation 12.6 mV
WheezyRider
1,690
938
After a break following Christmas and then an accident on the ice in January, I've started riding again this week and collecting data.
82 cycles now. After charging:
Charged to 41.013V:
Bank no. ) Voltage
1) 4.1013
2) 4.0998
3) 4.0982
4) 4.0967
5) 4.0982
6) 4.1092
7) 4.1018
8) 4.1038
9) 4.1007
10) 4.1067
Biggest variation 12.5 mV
Still no significant change...
WheezyRider
1,690
938
Today the pack finally passed the 100 Cycle mark!
Charged to 41.001V:
Bank no. ) Voltage
1) 4.0986
2) 4.0972
3) 4.0955
4) 4.0972
5) 4.0966
6) 4.1079
7) 4.1006
8) 4.1027
9) 4.0995
10) 4.1055
So 100 cycles, charging to 41V and no significant change in balance.
Bank 3 seems to be consistently the lowest voltage after charging and bank 6 the highest. However, bank 3 seems to maintain voltage better than some other banks when discharged, although these changes are tiny really.
Either this is an example of a well behaved pack, or the BMS is still balancing, even though it is only being charged to 41V and the balance feature is not supposed to activate until 4.18V is reached.
3,994
Have you checked with a meter when the bleed resistors start bleeding? Your whole test would be a waste of time if they're opening.
WheezyRider
1,690
938
Unfortunately the BMS is a sealed unit, so I can't get to the bleed resistors.
WheezyRider
1,690
938
However, even if the BMS is balancing at 41V, it's still a win, as without this experiment, I wouldn't know that it was.
I have another identical BMS and at some point I'll rig it up with some cells that are out of balance, charge at 41V and see what happens.
WheezyRider
1,690
938
Up to 150 cycles now.
Pack voltage 41.044V:
Bank no. ) Voltage
1) 4.1029
2) 4.1016
3) 4.0999
4) 4.1020
5) 4.1009
6) 4.1121
7) 4.1047
8) 4.1071
9) 4.1037
10) 4.1097
Maximum voltage difference 12.2 mV, so still no sign of the pack going out of balance.
WheezyRider
1,690
938
So after a year I finally got the pack back after lending it to someone with a charger set to 41V. It looks a little worse for wear now as it was attached with cable ties and gaffer tape to their bike! But it is still functioning fine.
53052
53053
It's been 3 years now of charging to 41V and hundreds of cycles.
In terms of the state of balance:
Pack voltage 40.882 V
Bank no. ) Voltage
1) 4.0856
2) 4.0872
3) 4.0830
4) 4.0883
5) 4.0835
6) 4.0957
7) 4.0872
8) 4.0920
9) 4.0861
10) 4.0939
So even after 3 years, the biggest variation between cells is still only 12.7 mV.
