Well finally the roads here have cleared so I went out for a ride the first in a week of so
Actually got to test the Turnigy meter in a real environment. Even back lit its quite hard to read so perhaps I need to mount it closer to my old eyes on the handle bars. I used the throttle a lot.
Quite interesting readings some matching what I expected and a few surprises.
On the flat if I am pedaling it barely goes over 1-2amps. On a small incline it goes up to 4-5amps but drops back to 2-3amps if I pedal.
On a steeper incline it goes up to about 8amps with me pedaling and about 10-12 if I stop.
Interestingly I had a peak of 17amps
The 15amp fuse didn't blow so it must have been for a m/s or so.
The total ride must have been about 5 miles though I don't have a trip computer fittted yet, must get one.
Readings
17.04 Ap
576.6 Wp
33.74 Vmin
1.69 Ah
61.8 Wh
Perhaps someone could help me with the Wp and Wh readings and tell me what these help show ? Can I work out more performance stats from my battery from these figures ? I assume the 33.74 Vmin was when I drew 17.04amps given the battery is 39.6v nominal ?
With 1.69Ah taken out the battery that leaves me 0.61Ah and its reading 39.13v so still 3.26v/cell assuming they are balanced. Thinking about it the battery is probably nearing discharge as I doubt it holds the full 2.3Ah though there was power left when I returned. I have to say I did not notice any drop in power really on the whole ride though, perhaps there was a fraction more if I didn't throttle for a bit and then tried again a few minutes later.
My cycle to work is about 5.25 miles so I think I probably could do a return journey (10.5 miles) on one charge, if I don't throttle a lot. I can easy take the charger to work or by a second one though.
Regards
Jerry
